I've always wanted a feature to be able to pull up recently opened files. Here is a patch that adds this to the File menu of the editor:
Created an issue in the google code issue tracker:
http://code.google.com/p/arduino/issues/detail?id=979
EDIT: This patch is broken (I broke it when I added truncating file names), see below
open-recent.patch (4.71 KB)
Quick question, how do you apply the patch?
system
July 10, 2012, 1:00am
3
Hi Tom,
I don't know what your background is, but to give a broad outline, you have to apply to the java source downloaded from github then rebuild the Arduino project.
http://code.google.com/p/arduino/wiki/GitandGithubGuideforArduinoDevelopment
To apply the patch, use the 'patch' command from the command line on unix, or cygwin. Or you can use the command 'git apply'
Typical usage would be:
$ cd
$ patch -p1 open-recent-file.patch
Then use 'ant' to re-build the project.
You could also pull the branch I posted from github just compile it if you just want to see what it looks like.
system
July 10, 2012, 3:12pm
4
Updated patch attached. Previous version saved filename with '...' characters in it, which you couldn't re-open, of course.
open-recent.patch (4.81 KB)
