Here is a sketch that controls the flashing, or blinking, of one LED.
Currently i am using the blink sketch to control the LED on/off time with a loop so it just flashes continuously as determined by the loop
I want to make a loop of the blink loop as well. I want to make a loop where the blink loop runs for X number of milliseconds, then it stops it for X number of milliseconds and so on.
So my question is how do you make loops on top of current loops?
/ Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
int freq = 10; // stimulation frequency
int dur = 10; // stimulation duration
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(dur); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(1000/freq); // wait for a second
Why not turn the led on and off with millis() instead of delay()?
Then you can vary the timing and do other things at the same time, like add a button that always works.
In your IDE under Examples->02.Digital->BlinkWithoutDelay shows how it's done with minor errors that only matter after 20-some days.
A more full explanation and exploration is at the address of the 1st Nick Gammon blog I list in my signature space below.
// constants won't change. Used here to
// set pin numbers:
const int ledPin = 13; // the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval; // interval at which to blink (milliseconds)
const long int_low=1000;
const long int_high=100;
long cycleMillis = 0;
long int_cycle;
const long int_cycle_off=3000;
const long int_cycle_on=5000;
int cycle_state;
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
interval = int_low;
int_cycle = int_cycle_on;
cycle_state = 1;
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if (cycle_state==1) {
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
Serial.println(currentMillis - cycleMillis);
ledState = HIGH;
interval = int_high;
else {
ledState = LOW;
interval = int_low;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
if (currentMillis - cycleMillis > int_cycle) {
Serial.println("CHANGE");
Serial.print("[");
Serial.print(currentMillis - cycleMillis);
Serial.println("]");
cycleMillis = currentMillis;
Serial.println("CICLE OFF");
cycle_state = 0;
int_cycle = int_cycle_off;
ledState = LOW;
else {
Serial.println("CICLE ON");
cycle_state = 1;
luisilva,
Thanks for the help the program works great!
I do have one more question. I'd like to add another cycle interval on top of the current cycle in the program.
Currently the led will pulse on and off at 30Hz for about 500ms and then stop for 2.5s. I'd like to run this cycle for a total of 60s min then stop it for 60 s.
Im back and have another programming question. I'd like to write the program to have the LED off first for 5 miin then LED on for 5 min at 30Hz. Currently the program above from Luisilva is written for the LED on first then LED off second. How should the program be rewritten to do this?
Here is the current code I have. Right now the program turns the LED on first for 30s then OFF for 5 min. I need to just switch the sequence and have the LED OFF for 5 min then on for 30s.
int ledState = LOW;
long interval;
const long int_low= 33;
const long int_high= 33;
long int_cycle;
const long int_cycle_off=300000;
const long int_cycle_on=30000;
int cycle_state;
long workingMillis = 0;
const long int_working=36000000;
int working_state;
long testMillis = 0;
const long int_test=1000;
interval = int_low;
cycle_state = 1;
working_state = 1;
if ( working_state == 1 ) {
if ( cycle_state == 1 ) {
if ( currentMillis - previousMillis >= interval ) {
if ( ledState == LOW ) {
ledState = HIGH;
else {
ledState = LOW;
interval = int_low;
if ( currentMillis - cycleMillis >= int_cycle ) {
Serial.print("[");
if (cycle_state == 1) {
Serial.print("#");
Serial.print(currentMillis - workingMillis);
Serial.println("#");
cycle_state = 0;
ledState = LOW;
else {
cycle_state = 1;
if (currentMillis - workingMillis >= int_working) {
Serial.println("##########");
Serial.print("#");
workingMillis = currentMillis;
if (working_state == 1) {
Serial.println("NOW I'M STOPED");
working_state = 0;
testMillis = 0;
ledState = LOW;
else {
Serial.println("NOW I'M WORKING");
working_state = 1;
// ONLY FOR DEBUG //
if ( working_state == 0 ) {
if ( currentMillis - testMillis >= int_test ) {
testMillis = currentMillis;
Serial.print("-");
Serial.println("-");
You should be able to reason that much out on your own ...
EDIT:
devinb23:
