Changed it to print on LCD, All seems to be working but there is one slight little issue.
On first power up all buttons values reads "0" on the LCD, Then I press a button then they all jump to "1" on the LCD, Then when I press the buttons from 0-7 they all go to "0" on the LCD which is correct I think.
How can I get them to start off form "1" ?
KeyPressed and leds with interrupt
by Mischianti Renzo <http://www.mischianti.org>
https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/
#include "Arduino.h"
#include "PCF8574.h" //https://github.com/xreef/PCF8574_library
#include <LiquidCrystal_I2C.h> // Libaray from here https://github.com/johnrickman/LiquidCrystal_I2C
LiquidCrystal_I2C lcd(0x3F, 20, 4); // Change to (0x27,20,4) for 20x4 LCD.
#include <Wire.h>
// For arduino uno only pin 1 and 2 are interrupted
#define ARDUINO_UNO_INTERRUPTED_PIN 2
uint8_t val0;
uint8_t val1;
uint8_t val2;
uint8_t val3;
uint8_t val4;
uint8_t val5;
uint8_t val6;
uint8_t val7;
bool startVal = HIGH;
bool keyPressed = false;
// Function interrupt
void keyPressedOnPCF8574();
// Set i2c address
PCF8574 pcf8574(0x20, ARDUINO_UNO_INTERRUPTED_PIN, keyPressedOnPCF8574);
unsigned long timeElapsed;
lcd.begin(); //set up the LCD's number of columns and rows
lcd.backlight(); //set LCD backlight on
lcd.clear();
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P7, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P4, INPUT);
Serial.print("Init pcf8574...");
if (pcf8574.begin()) {
Serial.println("OK");
Serial.println("KO");
if (keyPressed) {
val0 = pcf8574.digitalRead(P0);
val1 = pcf8574.digitalRead(P1);
val2 = pcf8574.digitalRead(P2);
val3 = pcf8574.digitalRead(P3);
val4 = pcf8574.digitalRead(P4);
val5 = pcf8574.digitalRead(P5);
val6 = pcf8574.digitalRead(P6);
val7 = pcf8574.digitalRead(P7);
keyPressed = false;
lcd.setCursor(0, 0);
lcd.print("B1:B2:B3:B4");
lcd.setCursor(0, 1);
lcd.print(val0);
lcd.print(" :");
lcd.print(val1);
lcd.print(" :");
lcd.print(val2);
lcd.print(" :");
lcd.print(val3);
lcd.print(" :");
lcd.setCursor(0, 2);
lcd.print("B4:B5:B6:B7");
lcd.setCursor(0, 3);
lcd.print(val4);
lcd.print(" :");
lcd.print(val5);
lcd.print(" :");
lcd.print(val6);
lcd.print(" :");
lcd.print(val7);
void keyPressedOnPCF8574() {
// Interrupt called (No Serial no read no wire in this function, and DEBUG disabled on PCF library)
keyPressed = true;
Not sure if this is the best method or not as I've seen a few ways people do it
From my original code posted above, If I highlight out this if (keyPressed) { } part it displays "1" on first power up and then "0" when each key is pressed.
Your code complies but gives "1" on start up and each button press it shows "0" but the LCD back light only flashes when I press a button and then goes off.
Same again if I remove the If(Keypressed){ } but leave in updateData and updatedisplay it works perfectly the same as my original code once I removed the if statement.
Just got to try now to had a debounce or slight delay as now I've added some more code (again all working ) but the issue now is I have to try and be fast to press and release the button other wise I get this as the results on the serial monitor, It dupiclates if I don't release fast enough or caused by debounce
DAC 1 & PORT A SELECTED
PORT A SELECTED: 1
DAC 2 SELECTED
DAC 2 SELECTED
DAC 2 & PORT B SELECTED
PORT B SELECTED: 4
PORT B SELECTED: 4
PORT B SELECTED: 4
PORT B SELECTED: 4
DAC 2 SELECTED
DAC 2 SELECTED
DAC 2 & PORT A SELECTED
PORT A SELECTED: 3
PORT A SELECTED: 3
DAC 1 SELECTED
DAC 1 SELECTED
MULTIPLIER SECLECTED
DAC 1 SELECTED
DAC 1 SELECTED
DAC 2 SELECTED
DAC 2 SELECTED
PORT A SELECTED: 3
I'll post the code in second post as it exceeds the character amount
This is the latest code with your modifications made
#include <Wire.h>
uint8_t val0;
uint8_t val1;
uint8_t val2;
uint8_t val3;
uint8_t val4;
uint8_t val5;
uint8_t val6;
uint8_t val7;
long lastDebounceTime = 0;
long debounceDelay = 50; //set a debounce
const byte Dac_multipliers[] = { 1, 10, 50, 100 };
const byte stepCount = sizeof(Dac_multipliers) / sizeof(Dac_multipliers[0]);
volatile byte currentStep = 0;
enum {DAC_1, DAC_2}; // Select DAC 1 or DAC 2
volatile boolean Select_Channel = DAC_1; //Set Channel to DAC 1 on power up
enum { CHAN1_CHAN_A, CHAN1_CHAN_B, CHAN2_CHAN_A, CHAN2_CHAN_B }; // constants for current channel
volatile boolean Set_currentChannel = CHAN1_CHAN_A; //Set DAC 1, PORT A on power up
int Dac_volts[] = {1600, 990, 1598, 998}; //Set initial Dac_volt.
int Dac1_min_volts;//Sore Min motor 1&2
int Dac2_min_volts;//Store min Motor 3&4
byte Port_select[4];
int KeyChannelSelect = 0;
int Enable_encoder = 0;
// Set i2c address
void updateData()
void updateDisplay()
lcd.print(Dac_volts[CHAN1_CHAN_A]);//Display Dac Value
lcd.print(" V1 ");
lcd.print(Dac_volts[CHAN2_CHAN_A]);//Display Dac Value
lcd.print(" V2 ");
lcd.print(Dac_volts[CHAN1_CHAN_B]);// Just show multiplier value,Will be removed
lcd.print(" A1 ");
lcd.print(Dac_volts[CHAN2_CHAN_B]);// Just show multiplier value,Will be removed
lcd.print(" A2 ");
lcd.print(Port_select[0]);
lcd.print(" : ");
lcd.print(Port_select[1]);
lcd.print(" : ");
lcd.print(Port_select[2]);
lcd.print(" : ");
lcd.print(Port_select[3]);
lcd.print(" : ");
lcd.print(KeyChannelSelect);
// lcd.print(CHANNEL_1);// Just show multiplier value,Will be removed
//##### SET DAC 1 PORT A&B ############
if (Select_Channel == DAC_1 && KeyChannelSelect == 1 && Port_select[0] == 1) {
lcd.print("SET DAC 1 PORT A ");
// dac_Channel1.setVoltageA(Dac_volts[CHAN1_CHAN_A]); // Send the Dac Value out on Port B
if (Select_Channel == DAC_1 && KeyChannelSelect == 1 && Port_select[1] == 2) {
lcd.print("SET DAC 1 PORT B ");
// dac_Channel1.setVoltageB(Dac_volts[CHAN1_CHAN_B]); // Send the Dac Value out on Port B
//##### SET DAC 2 PORT A&B ############
if (Select_Channel == DAC_2 && KeyChannelSelect == 2 && Port_select[2] == 3) {
// dac_Channel2.setVoltageA(Dac_volts[CHAN2_CHAN_A]); // Send the Dac Value out on Port B
lcd.print("SET DAC 2 PORT A ");
if (Select_Channel == DAC_2 && KeyChannelSelect == 2 && Port_select[3] == 4) {
// dac_Channel2.setVoltageB(Dac_volts[CHAN2_CHAN_B]); // Send the Dac Value out on Port B
lcd.print("SET DAC 2 PORT B ");
lcd.clear();
Port_select[0] = 1;
KeyChannelSelect = 1;
updateData();
updateDisplay();
updateData();
updateDisplay();
inputAction();
keyPressed = true;
void inputAction() {
//# button 0 sets the Multippler #
if (val0 == 0) {
currentStep++;
if ( currentStep >= stepCount ) currentStep = 0;
Serial.println("MULTIPLIER SECLECTED "); // Just added to see if there is any output on power up(DEBUGING ONLY)
//# button 1 Select dac 1 #
if (val1 == 0) {
Serial.println("DAC 1 SELECTED "); // Just added to see if there is any output on power up(DEBUGING ONLY)
//# button 2 selectt dac 2 #
if (val2 == 0 ) {
Select_Channel = DAC_2;
KeyChannelSelect = 2;
Serial.println("DAC 2 SELECTED "); // Just added to see if there is any output on power up(DEBUGING ONLY)
//# button 3 DAC 1 PORT A #
if (val3 == 0 && Select_Channel == DAC_1) {
Dac1_min_volts = 1600;
Port_select[0] = 1;
Port_select[1] = 0;
Port_select[2] = 0;
Port_select[3] = 0;
currentStep = 0;
Serial.println("DAC 1 & PORT A SELECTED "); // Just added to see if there is any output on power up(DEBUGING ONLY)
Serial.print("PORT A SELECTED: ");
Serial.println(Port_select[0]);
//# button 4 DAC1 1 PORT B #
if (val4 == 0 && Select_Channel == DAC_1) {
Set_currentChannel = CHAN1_CHAN_B;
Port_select[0] = 0;
Port_select[1] = 2;
Port_select[2] = 0;
Port_select[3] = 0;
currentStep = 0;
Dac1_min_volts = 990;
Serial.println("DAC 1 & PORT B SELECTED "); // Just added to see if there is any output on power up(DEBUGING ONLY)
Serial.println(Port_select[1]);
//# button 3 DAC 2 PORT A #
if (val3 == 0 && Select_Channel == DAC_2) {
Set_currentChannel = CHAN2_CHAN_A;
Port_select[0] = 0;
Port_select[1] = 0;
Port_select[2] = 3;
Port_select[3] = 0;
Dac1_min_volts = 1598;
currentStep = 0;
Serial.println("DAC 2 & PORT A SELECTED "); // Just added to see if there is any output on power up(DEBUGING ONLY)
Serial.println(Port_select[2]);
//# button 4 DAC 2 PORT B #
if (val4 == 0 && Select_Channel == DAC_2) {
Set_currentChannel = CHAN2_CHAN_B;
Port_select[0] = 0;
Port_select[1] = 0;
Port_select[2] = 0;
Port_select[3] = 4;
currentStep = 0;
Dac1_min_volts = 988;
Serial.println("DAC 2 & PORT B SELECTED "); // Just added to see if there is any output on power up(DEBUGING ONLY)
Serial.print("PORT B SELECTED: ");
Serial.println(Port_select[3]);
