Hey guys, Im new to arduino, I was wondering how I would control this Peltier Device with this Motor Driver. I'm looking at the schematics but the concept is still hazy to me.
Peltier is required to heat/cool only a 25mL sample.
I want to know how to set up the driver on the breadboard.
Thanks,
Tenzin
That motor driver would probably work for that particular Peltier module, but you are taking a risk as the current drawn will be near the maximum for the motor driver.
That is a pretty wimpy Peltier module and won't move much heat. The most common ones are rated at around 60-70 watts, and draw 6 amperes or so at 12 V, and cost about the same.
You will need a separate power supply for the Peltier module. The Arduino 5V output cannot provide the required current. Connect all the grounds together.
