Peltier Device, and Thermal sensor
Hey guys, I'm pretty new to Arduino I was wondering how i would go ahead and use a 5V 1A peltier device along with arduino. As I understand, the peltier device requires a lot more amperage than the Uno can supply. I really appreciate the help!
Specifically these products
Hi, welcome to the forum.
As you can read on the Adafruit website, it is 5V 1.5A "so we suggest our 5V/2A power adapter for use".
To turn the Peltier on and off, you can use a relay or mosfet.
If you have a Peltier element without anything attached, one side (the 'hot' side) might get too hot.
Peter_n:
Hi, so along with the thermal sensor, will 2A be enough?
Yes. The Arduino board uses little current and the DS18B20 almost nothing.
Both Adafruit and Sparkfun sell the DS18B20 : Waterproof 1-Wire DS18B20 Digital temperature sensor : ID 381 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits
They are also on Ebay : ds18b20 -without for sale | eBay
P.S.: You can use the "REPLY" button or the "Quick Reply" text field. There is no need to use "Quote" since my post is already there :wink:
Ahh i see, So the MOSFET is also used to change the direction of current, if i want to switch between hot and cold? Or is this a different procedure?
A mosfet is only for on and off.
To change the voltage, you need a H-bridge.
Two simple relays can be used, or a H-bridge module.
This is a relay shield : http://www.seeedstudio.com/wiki/Relay_Shield_V2.0
The H-bridge modules are often used for motors, but can also be used for Peltier elements.
This might work: Pololu - DRV8838 Single Brushed DC Motor Driver Carrier
So this means that I would also need to reconsider the choice of power adapter as well right? Also, Thank you for the speedy replies
No, why do you think that ?
I assume that the Peltier does not require more that 1.5A at 5V.
So you need a relay or H-bridge module that can switch at least 1.5A.
If the relay can switch 10A, that's fine. If the H-bridge can switch 2A or 5A, that's okay.
Some relays need 12V to work, but let's not use those. I think for your project 5V relays are easier.
Not all H-bridge modules work at 5V for the output, so you have find one that does.
If you are considering reversing the direction of the Peltier cold/heat, you need to let the device rest for at least 5 minutes before reversing.
Paul
Paul_KD7HB:
Paul
This is to... prevent sudden temperature changes from causing cracking and failure of the peltier junction, or is it something more complicated?
DrAzzy:
Just that. Mine ran for about a week, doing an immediate switch from cold to hot, then 15 minutes later an immediate switch back to cold. Only a single cycle per day. After adding a 5 minute pause between power, I found the place on the Peltier that was not properly sealed and moisture condensed inside the unit and ran out the bottom. That unit lasted just a couple of days. Am waiting for another Peltier device and will inspect it thoroughly.
Paul
If i use the h bridge will I still need the mosfet? I'm looking at this diagram and I dont see a mosfet anywhere on it.
No. A mosfet can be as a switch, to turn something on or off. An H-bridge is used to also change the polarity.
In the picture is a mosfet for the fan.
I dont actually require that fan. I just need to power the peltier device and change polarity. Will I need the mosfet for the peltier device?
Noooo, the H-bridge will do that.
Thanks Peter!
