// just to share
Today I was playing with the map function, including looking at effects of integer overflow and how to prevent them.
If one uses large values the internal (integer) math can overflow causing serious trouble
long x = map(i, 0, 1000000, 1000000, 100000000);
A solution to this is doing the math in float and loose some precision. Because float math is considered slower than integer math I decided to do some timing and I found out that a local written float mapf() function was 10x as fast as the map function!
The reason for this is that as the parameters are all known at compile time the compiler optimized almost all math away. (fastest math = no math). Same is true for a local written long mapl(), much faster than the library map() function, because it can be optimized aggressively.
This means that if one uses the map function a lot and one needs speed, there are dozens of microseconds to be gained per call if the mapping ranges are known compile time. The sketch below shows the differences
uint32_t start;
uint32_t stop;
long d[10];
Serial.println("Start ");
for (long i = 1; i <= 1000000; i*=10)
start = micros();
d[0] = micros() - start;
start = micros();
long a = mapl(i, 0, 1000000, 1000000, 100000000);
d[1] = micros() - start;
start = micros();
long z = mapf(i, 0, 1000000, 1000000, 100000000);
d[2] = micros() - start;
Serial.print(i);
Serial.print("\t");
Serial.print(x);
Serial.print("\t");
Serial.print(a);
Serial.print("\t");
Serial.println(z);
for (int i=0; i<3 ; i++)
Serial.print('\t');
Serial.print(d[i]);
long mapl(long x, long in_min, long in_max, long out_min, long out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
float mapf(long x, float in_min, float in_max, float out_min, float out_max)
void loop(){}
output (every second line is the timing.
1 1000099 1000099 1000099
56 0 4
10 1000990 1000990 1000990
60 4 4
100 1001310 1001310 1009900 // long overflow !!!
60 4 4
1000 1000215 1000215 1099000
56 4 8
10000 997863 997863 1990000
56 4 4
100000 1000100 1000100 10900000
60 8 4
1000000 1001003 1001003 100000000
56 0 4
Note:
- the locally defined mapl has also long overflow
- the locally defined mapf() gives the correct answer
(more precisely in the right order of magnitude as floats have less significant digits than long) - performance gain factor 10+ due to local definition
So back to the original question, how to prevent integer overflow in the mapping function?
- use a local defined mapf() function to prevent the overflow
- use compile time known ranges to squeeze out performance.
During the tests I found a variant of the map() function having an interesting interface and performance.
long mapf(long x, long px, long py, float slope)
return (x - px) * slope + 0.5 + py; // includes rounding
px, py describes any point on the line (preferably 0, py or px, 0) and slope describes the slope/steepness of the line
the advantage of this map function is it has no (expensive) integer division but a float multiply.
first order measurement showed it is 10-15% faster than the normal map function. (but footprint is bigger due to float!)
update: not tested is a version where px and py are floats too
