PH meter SKU SEN0161 v1.0
Hello All,
I am using PH meter SKU SEN0161 v1.0.
I calibrated my device with pH7 and the voltage for pH7 is 1.89.
Whenever i put my ph sensor in ph4 solution, it drop down the value
Voltage:0.23 pH:1.20
and for pH5 solution it shows below value.
Voltage:0.66 pH:2.70
Can somebody will help me in this regards?
Thanks in advanced.
Here is my code:
#define SensorPin A0
#define Offset 0.00
#define LED 13
#define samplingInterval 20
#define printInterval 800
#define ArrayLenth 40
int pHArray[ArrayLenth];
int pHArrayIndex=0;
void setup(void)
pinMode(LED,OUTPUT);
Serial.println("pH meter experiment!");
void loop(void)
static unsigned long samplingTime = millis();
static unsigned long printTime = millis();
static float pHValue,voltage;
if(millis()-samplingTime > samplingInterval)
pHArray[pHArrayIndex++]=analogRead(SensorPin);
if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
voltage = avergearray(pHArray, ArrayLenth)5.0/1024;
pHValue = 3.5
voltage+Offset;
samplingTime=millis();
if(millis() - printTime > printInterval)
Serial.print("Voltage:");
Serial.print(voltage,2);
Serial.print(" pH value: ");
Serial.println(pHValue,2);
digitalWrite(LED,digitalRead(LED)^1);
printTime=millis();
double avergearray(int* arr, int number){
int i;
int max,min;
double avg;
long amount=0;
if(number<=0){
Serial.println("Error number for the array to avraging!/n");
return 0;
if(number<5){
for(i=0;i<number;i++){
amount+=arr[i];
avg = amount/number;
return avg;
}else{
if(arr[0]<arr[1]){
min = arr[0];max=arr[1];
else{
min=arr[1];max=arr[0];
for(i=2;i<number;i++){
if(arr[i]<min){
amount+=min; //arr<min
min=arr[i];
}else {
if(arr[i]>max){
amount+=max; //arr>max
max=arr[i];
}else{
amount+=arr[i]; //min<=arr<=max
}//if
}//for
avg = (double)amount/(number-2);
}//if
return avg;
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
Do have a datasheet of your pH-sensor that has information about what pH-value should give what voltage ? at least as a rough estimation?
Do you have a second and calibrated pH-meter to cross-check if your 4 pH-solution is really pH 4?
best regards Stefan
Thank you for response.
i finally figured it out its solution.
best Regards Ashish
