I have set up a basic arduino circuit with a Photot Resistor and 10k resistor to give readings of light levels. I have connected it to my computer and using it with Grasshopper and it has successfully given me a figure but I don't know what meausurement this figure is in? Does anyone know if this is Lumens? Or know how to convert this number to Lumens?
There's no fixed rule to convert to lumens either - all photoresistors are different. The numbers you're getting also depend on how you connect it up to the Arduino and (I think) on the temperature of the photoresistor.
To work out the conversion you'd have to calibrate the circuit yourself e.g. borrow a calibrated light meter, take readings at a series of different light intensities and compare with what numbers the arduino measures. Then make a sketch that does the maths to convert from raw numbers to lumens.
Without looking at your code, I would say you are just reading the 0 to 1023 count directly from the AtoD of the arduino that is connected to the LDR and 10k.
Actually converting to lumens would be a problem as the LDR response would not be linear, so neither would the AtoD output.
