In file included from C:\Users\jJc\Documents\Arduino\files\oversized_volume_knob\oversized_volume_knob\oversized_volume_knob.ino:3:0:
C:\Users\jJc\Documents\Arduino\libraries\encoder-volume/ClickEncoder.h:18:10: fatal error: avr/io.h: No such file or directory
#include <avr/io.h>
compilation terminated.
exit status 1
Error compiling for board Raspberry Pi Pico.
I'm not much of a coder and i really need help. Can someone please help me?
Hello, You are correct. After reading up on the whole error it is for an avr. Yes I do have the arduino pi pico bootloader on it. I'm able to do a lot of things such as the oled and other things with no problem.
hello, Just an update. I finally mange to find a arduino nano. I tried the code and got errors. I couldn't get it to work. The error stats that
In file included from C:\Users\jJc\AppData\Local\Temp\arduino_modified_sketch_837413\oversized_volume_knob.ino:5:0:
C:\Users\jJc\Documents\Arduino\libraries\HID\src/HID-Project.h:35:2: error: #error HID Project can only be used with an USB MCU.
exit status 1
Error compiling for board Arduino Nano.
It looks like it wants a arduino leonardo that has native USB on it. something I do not have. Here is the sketch.
// Read the full tutorial at prusaprinters.org
#include <ClickEncoder.h>
#include <TimerOne.h>
#include <HID-Project.h>
#define ENCODER_CLK 5 // Change A0 to, for example, A5 if you want to use analog pin 5 instead
#define ENCODER_DT 4
#define ENCODER_SW 3
ClickEncoder *encoder; // variable representing the rotary encoder
int16_t last, value; // variables for current and last rotation value
void timerIsr() {
encoder->service();
Serial.begin(9600); // Opens the serial connection used for communication with the PC.
Consumer.begin(); // Initializes the media keyboard
encoder = new ClickEncoder(ENCODER_DT, ENCODER_CLK, ENCODER_SW); // Initializes the rotary encoder with the mentioned pins
Timer1.initialize(1000); // Initializes the timer, which the rotary encoder uses to detect rotation
Timer1.attachInterrupt(timerIsr);
last = -1;
value += encoder->getValue();
// This part of the code is responsible for the actions when you rotate the encoder
if (value != last) { // New value is different than the last one, that means to encoder was rotated
if(last<value) // Detecting the direction of rotation
Consumer.write(MEDIA_VOLUME_UP); // Replace this line to have a different function when rotating counter-clockwise
Consumer.write(MEDIA_VOLUME_DOWN); // Replace this line to have a different function when rotating clockwise
last = value; // Refreshing the "last" varible for the next loop with the current value
Serial.print("Encoder Value: "); // Text output of the rotation value used manily for debugging (open Tools - Serial Monitor to see it)
Serial.println(value);
// This next part handles the rotary encoder BUTTON
ClickEncoder::Button b = encoder->getButton(); // Asking the button for it's current state
if (b != ClickEncoder::Open) { // If the button is unpressed, we'll skip to the end of this if block
//Serial.print("Button: ");
//#define VERBOSECASE(label) case label: Serial.println(#label); break;
switch (b) {
case ClickEncoder::Clicked: // Button was clicked once
Consumer.write(MEDIA_PLAY_PAUSE); // Replace this line to have a different function when clicking button once
case ClickEncoder::DoubleClicked: // Button was double clicked
Consumer.write(MEDIA_NEXT); // Replace this line to have a different function when double-clicking
delay(10); // Wait 10 milliseconds, we definitely don't need to detect the rotary encoder any faster than that
// The end of the loop() function, it will start again from the beggining (the begginging of the loop function, not the whole document)
This is just a long comment
Here are some fun functions you can use to replace the default behaviour
Consumer.write(CONSUMER_BRIGHTNESS_UP);
Consumer.write(CONSUMER_BRIGHTNESS_DOWN);
Consumer.write(CONSUMER_BROWSER_HOME);
Consumer.write(CONSUMER_SCREENSAVER);
Consumer.write(HID_CONSUMER_AL_CALCULATOR); //launch calculator :)
Consumer.write(HID_CONSUMER_AC_ZOOM_IN);
Consumer.write(HID_CONSUMER_AC_SCROLL_UP);
CONSUMER_SLEEP = 0x32,
FULL LIST CAN BE FOUND HERE:
https://github.com/NicoHood/HID/blob/master/src/HID-APIs/ConsumerAPI.h
I'm unsure what to do now. I can not find anything that use a rotary encoder for a volume control on a uno or nano board. Does anyone know where I can find something like that?
