PID ball stabilization
Hi guys. Can someone be able to help me with this school project? I have a project in which I would to stabilizce ball in the middle of the plane between two such guide rods by tuning the parameters of a PID controller (algorithm). I use stepper motor NEMA 17 to control the platform and stepper motor driver TMC2209. I use two laser sensor VL53L0X V2, each on one side, to measure the ball distance. I need help with programming. Any advice for help will be appreciated. Thank you. :slight_smile:
code sample what I have written so far:
#include "Adafruit_VL53L0X.h"
#define LOX1_ADDRESS 0x37
#define LOX2_ADDRESS 0x38
#define SHT_LOX1 12
#define SHT_LOX2 11
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
int distanceLeft, distanceRight;
int EN_pin = 10;
int DIR_pin = 3;
int STEP_pin = 4;
int MS1 = 9;
int MS2 = 8;
float Kp = 8;
float Ki = 0.2;
float Kd = 3100;
float proportionalTerm = 0;
float integralTerm = 0;
float derivativeTerm = 0;
float PID_output = 0;
float error = 0;
float previousError = 0;
float center = 0;
float inputDistance = 0;
long currentTime = 0;
long previousTime = 0;
float timeDifference = 0;
void setID() {
  // all reset
  digitalWrite(SHT_LOX1, LOW);
  digitalWrite(SHT_LOX2, LOW);
  delay(10);
  // all unreset
  digitalWrite(SHT_LOX1, HIGH);
  digitalWrite(SHT_LOX2, HIGH);
  delay(10);
  // activating LOX1 and resetting LOX2
  if(!lox1.begin(LOX1_ADDRESS)) {
    Serial.println(F("Failed to boot first VL53L0X"));
    while(1);
  delay(10);
  delay(10);
  if(!lox2.begin(LOX2_ADDRESS)) {
    Serial.println(F("Failed to boot second VL53L0X"));
    while(1);
// Function to read distances from both sensors
void read_dual_sensors() {
  // Measure distance from sensor LOX1
  lox1.rangingTest(&measure1, false);
  // Measure distance from sensor LOX2
  lox2.rangingTest(&measure2, false);
  Serial.print(F("1: "));
  if(measure1.RangeStatus != 4) {
    Serial.print(measure1.RangeMilliMeter);
    distanceLeft = measure1.RangeMilliMeter;
    Serial.print(F("Out of range"));
  Serial.print(F(" "));
  Serial.print(F("2: "));
  if(measure2.RangeStatus != 4) {
    Serial.print(measure2.RangeMilliMeter);
    distanceRight = measure2.RangeMilliMeter;
  while (!Serial) { delay(1); }
  pinMode(SHT_LOX1, OUTPUT);
  pinMode(SHT_LOX2, OUTPUT);
  Serial.println(F("Shutdown pins initialized..."));
  Serial.println(F("Both in reset mode...(pins are low)"));
  Serial.println(F("Starting..."));
  setID();
  pinMode(EN_pin, OUTPUT);
  pinMode(DIR_pin, OUTPUT);
  pinMode(STEP_pin, OUTPUT);
  digitalWrite(EN_pin, LOW);
  digitalWrite(DIR_pin, HIGH);
  digitalWrite(MS1, HIGH);
  digitalWrite(MS2, HIGH);
  read_dual_sensors();
  if (distanceLeft != -1 && distanceRight != -1)
      currentTime = millis();
      timeDifference = currentTime - previousTime;
      if(distanceLeft < 200) error = distanceLeft - 200;
      else error = 200 - distanceRight;
      proportionalTerm = Kp * error;
      derivativeTerm = Kd * ((error - previousError) / timeDifference);
      if (-30 < error && error < -5 || 5 < error && error < 30 )
          integralTerm = integralTerm + (Ki * error * timeDifference);
          integralTerm = 0;
      PID_output = proportionalTerm + integralTerm + derivativeTerm;
      previousError = error;
      previousTime = currentTime;
      Serial.println(PID_output);
  delay(100);
What works, what does not?
I would need to add code to control a stepper motor based on calculating PID
The PID algorithm calculations should work. I just don't know how to synchronize it with the stepper motor.
Take a look how it's done here:
Thank you
