PID+LCD Displayed Weird Char (Arduino Uno)
Hi...
I'm a final year student and I face a little problem with my final project.
I want to make a device that can maintain the heating temperature at 37'C and display the current temperature on LCD..
I'm using the Peltier 12710 as the heating element and thermistor as my temperature sensor.
I also print the current temperature and plot the temperature graph on Matlab.
The problem is, I don't know why my LCD suddenly displayed weird character when it reached the Setpoint.
I set my setpoint = 636 which is equal to 37'C.
Please someone help me because I don't know what else to do. Already run out of ideas. =(
I'm a noob here, please help me~~
// Tuning parameters
float Kp=30; //Initial Proportional Gain
float Ki=0.000015; //Initial Integral Gain
float Kd=0;  //Initial Differential Gain
double Setpoint, Input, Output;  //These are just variables for storing values
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT); // This sets up our PDID Loop
const int sampleRate = 1; // Variable that determines how fast our PID loop runs
//// Communication setup
const long serialPing = 500; //This determines how often we ping our loop
//// Serial pingback interval in milliseconds
// Initialize the LiquidCrystal library with the numbers of the interface pins.
// LiquidCrystal(rs, e, d4, d5, d6, d7)
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);    //initialize the LCD library with the numbers of the interface pins
float pad = 9850;
float Thermistor(int RawADC) {
  long Resistance;
  float Temp;                                        // Dual-Purpose variable to save space.
  Resistance=((1024 * pad / (RawADC)) - pad);
  Temp = log(Resistance);                            // Saving the Log(resistance) so not to calculate  it 4 times later
  Temp = 1 / (0.001129148 + (0.000234125 * Temp) + (0.0000000876741 * Temp * Temp * Temp));
  Temp = Temp - 273.15;                              // Convert Kelvin to Celsius
  return Temp;                                       // Return the Temperature
void setup(){
  Serial.begin(9600); //Start a serial session
  Setpoint = 636;
  myPID.SetMode(AUTOMATIC);  //Turn on the PID loop
  myPID.SetSampleTime(sampleRate); //Sets the sample rate
  myPID.SetOutputLimits(0,255);
  lcd.begin(16,2);           //set up the LCD's number of columns and rows
  lcd.setCursor(0, 0);
  lcd.print("Current Temp('C)");        //Current Temp to the LCD
void loop(){
  Setpoint = 636;   // 37.C @ analog 636
  tempLevel = analogRead(ThermistorPIN); //Get the temperature
  Input = map(tempLevel,0,1024,0,1024);
  myPID.Compute();  //Run the PID loop
  analogWrite(heater, Output);  //Write out the output from the PID loop to our LED pin
  DispTemp ();
void DispTemp (){
  float displayTemp;
  for(i = 0;i<=7;i++){ // gets 8 samples of temperature
  samples[i] = Thermistor(analogRead(ThermistorPIN));
  displayTemp = displayTemp + samples[i]; // do the addition for average temperature
  delay(100); // wait 100ms
  } //End for Loop
  displayTemp = displayTemp/8.0;
  Serial.println(displayTemp);      // Send data to Matlab
  lcd.setCursor(5,1);
  lcd.print(displayTemp,1);            //print the value to LCD
  lcd.print("'C");
  delay (100);
void loop(){
Why do you need to set the set point on every pass through loop()?
Mapping with the to range the same as the from range is stupid. All it does is waste time.
  } //End for Loop
Why do you need an array of values? You never use the array, so get rid of it.
What does that value correspond to? Is it reasonable, given all the delay()s in the code?
Does your LCD.print() accept non-string inputs? You might need to format it to a string.
I just found the cause of the problem. Its just because of grounding. :sweat_smile:
Before this the LCD's GND pin is connected to the 12V GND.
Then when I connect the LCD's GND pin to the Arduino's GND, my LCD can display well (no more weird char).
My bad... :sweat_smile:
Thanks all XD XD XD
Thanks PaulS :slight_smile:
Thanks mirith :slight_smile:
