It's a bit long winded but I think it really simplifies how a PID controller works. I'm working on some more graphics I hope to have up shortly but due to some problems with my PC I was forced into using the Draw function of google docs.
The post is an overview of the theory behind a PID and what one can do for you and your projects. The code for the algorithms themselves will run just fine on the Arduino given a sensor input. PID controllers are an essential control system for robotics and automation, I hope my tutorial will make them a bit more understandable.
Hmmm, I wonder if googles only letting me see them because I'm logged in... I'm working on real graphics in matlab to model the actual equations so better ones should be coming. Thanks for letting me know!
So apparently squarespace and google chrome beta don't play nice. There were whole embedded menus in the article amongst other quirks. Any questions Andrew?
No questions thanks, I was only reading it out of interest. One day if I ever get around to building a self-balancing robot I expect to have to use a PID controller.
Its a control method for getting your desired output (output 12V, turn 32 degrees right, fly east, find the red candy...) as optimally as possible by using three gains (scalar multiplication). One for the current value (proportional P), one for the the integral of the current value(integral I), and the last for derivative of the current value(derivative D). By tuning these gains correctly, you end up with a controller that percent overshoot (bounce), rise time(time to get where you want), settling time (time to stop oscillation), and steady state error (difference in what you got from what you wanted).
Yea, PID control is exactly what I NEED on my laminator temperature controller rather than just turning off when it hits temperature setpoint, then staying off until it gets 2 degrees below setpoint before turning back on again.
PID is how "real" control is done.
Thanks - maybe I can learn enough to use the algorithms and improve my temperature controller.... of course I'll need to be able to "modulate" the heat rather than just OFF or ON.
I'm fine thank you I did not catch it from you, but you should go see someone about it before it hurts someone more significant. than little old party clown me.
This is interesting and I see how to use on robots to minimise power use and damage. Must study formula more closely
