Dear All
thank you in advance for the help. I am seeing a strange behaviour. My Arduino 2560 (i have 2 of them) are not allowing me to take inputs from pin 22-45. I want to use them as digital pins and simply use digitalRead to get the signal. I am however not getting anything or getting a constant one.
Interestingly if I simply configure them as digital output I am able to light up a LED with the pins.
If it helps I am using a capacitive switch as input which has 5 V.
Also when I change the pin to say 2 the code works!
any help is appreciated
Here is the code
int b1=0;
pinMode(22, INPUT); //pod1_button1
Serial.println(digitalRead(22));
thanks
Kanav
