Hello,
I have an arduino nano RP2040 connect and i need to connect an openlog datalogger just like the sparkfun datalogger. i need only for the datalogger to receive data and data to be written on. It uses standart UART. However, i am already using the D0 and D1 pins on the Arduino which are the starnarde Rx and Tx pins. I am using them for an oxygen sensor which needs the UART.
Question 1: Can I connect the Rx pin of the data logger to the D8 pin on the arduino so that it can act as a Tx and it is in the UART1 not UART0. I dont know if that is relevant though? Please do let me know. And do I need any code to set that up
Question 2: Can I still transmit the data to the datalogger just with that one conection plus VCC and GND
// Note (also on RPi Pico W)
// Serial is the USB serial for program loading and serial mointor
// there are two hardware serial ports UART0 and UART1
// Serial1 is mapped to UART0 on Rx pin GP1 Tx pin GP0
// Serial2 is mapped to UART1 on Rx pin GP5 Tx pin GP4
program testing Serial2
// Raspberry Pi Pico RP2040 (and W) Serial2 test - for loopback test connect pins Tx GP4 and Rx GP5
#include <Arduino.h>
#define TX2 4
#define RX2 5
// initialize both serial ports:
delay(2000);
Serial.println("\n\nRaspberry Pi Pico RP2040 serial2 test Rx pin GP5 Tx pin GP4 ");
Serial.write(" for loopback test connect pin GP4 to pin GP5\n");
Serial2.setTX(TX2);
Serial2.setRX(RX2);
Serial2.begin(115200);
Serial.print(" Serial2 RX2 is on pin GP " + String(RX2));
Serial.println(" TX2 pin: " + String(TX2));
// read from port 1, send to port 0:
if (Serial2.available()) {
int inByte = Serial2.read();
Serial.write('>');
Serial.write(inByte);
// read from port 0, send to port 1:
if (Serial.available()) {
int inByte = Serial.read();
//Serial.write(inByte);
Serial2.write(inByte);
