Hello Delta
The pin 7 goes directly to the relais board... so i can not limit the current there... all other circuilt ar limited with resistors. and the external power on vin is 12vdc 1amp...
the code is down there..
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
//#include <WiFi.h>
#include <Arduino_GigaDisplay.h>
#include <Arduino_GigaDisplay_GFX.h>
#include <lvgl.h>
//#include <SPI.h>
#include <Ethernet.h>
#include <USBHostGiga.h>
/* Start Keyboard and Serial Communication */
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
/* Variables needed during processing */
String ku_lock = "True";
String ku_name = "";
String ku_result = "";
String ku_rest = "";
int ku_prg = 0;
unsigned long t_start, t_end;
unsigned long timer_1, timer_2;
Keyboard keyb; // create the object
HostSerial ser; // create the object
GigaDisplay_GFX display; // create the object
// ---------- Ethernet Config ---------- //
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 78);
IPAddress myDns(8, 8, 8, 8);
// ---------- WiFi Config -------------- //
//char ssid[] = "Fragilia"; // your network SSID (name)
//char pass[] = "Markus_Barbara1"; // your network password (use for WPA, or use as key for WEP)
//int status = WL_IDLE_STATUS; // the WiFi radio's status
EthernetClient client;
//WiFiClient wclient;
// ---------- Server Config ---------- //
char server[] = "www.breitenstein.ag"; // name address for Google (using DNS)
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true; // set to false for better speed measurement
String rfid; // string for the RFID
bool rfid_ok = false; // boolean for RFID validation
int count = 1; // counter for Keyboard
int runonce = 0; // value 0 ist a onetimer inside the loop
String text = ""; // text for print function
/* PIN declaration */
int wash = 6 ; //Relais 3 Pin
int lift = 7 ; //Relais 4 Pin
pinMode(6, OUTPUT); // Relais Waschen
pinMode(7, OUTPUT); // Relais Lift
pinMode(22, INPUT); // Input Programm 1
pinMode(24, INPUT); // Input Programm 2
pinMode(23, INPUT); // Input Start
pinMode(25, INPUT); // Input Stop
pinMode(28, OUTPUT); // LED BLAU
Serial.begin(115200);while (!Serial) { ; } // wait for serial port to connect. Needed for native USB port only
display.begin(); // enable display
display.fillScreen(BLACK); // display backcolor
display.setRotation(3); // display rotation
display.setTextSize(4); // display text size
pinMode(PA_15, OUTPUT); // enable keyboard on USB A
keyb.begin(); // start keyboard scanner
ser.begin(); // start serial communication on ethernet shield
// start th wifi connection
// if (WiFi.status() == WL_NO_MODULE) { Serial.println("Communication with WiFi module failed!"); display.println("Communication with WiFi module failed!"); while (true); }
// while (status != WL_CONNECTED) { Serial.print("Attempting to connect SSID: "); Serial.println(ssid); display.print("Attempting to connect SSID: "); display.println(ssid); status = WiFi.begin(ssid, pass); delay(1000); }
// start the Ethernet connection:
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
Ethernet.begin(mac, ip, myDns); // try to congifure using IP address instead of DHCP:
display.print("DHCP assigned IP ");
display.println(Ethernet.localIP());
// give the Ethernet shield a second to initialize:
if (client.connect(server, 80)) {
Serial.print("connected to ");
Serial.println(client.remoteIP());
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
Serial.println("connection ok");
// if you didn't get a connection to the server:
Serial.println("connection failed");
beginMicros = micros();
Serial.println("start loop");
digitalWrite(28, HIGH);
display.setTextColor(WHITE);
display.setCursor(30, 200); display.println("Halten Sie bitte die RFID");
display.setCursor(30, 270); display.println("an den Sensor.");
while (ku_lock == "True"){
if (rfid.length() <= 8) {
if (keyb.available()) {
for (int count = 1; count < 22; count ++){
auto _key = keyb.read();
if (keyb.getAscii(_key) != NULL) {
if (pow(-1,count) <= 0){
rfid += keyb.getAscii(_key);
Serial.println(count);
delay(30);
rfid=rfid.substring(0,8); Serial.println(rfid); display.println(rfid);
if (rfid.length()>=8) { RFID_Check(); }
} // Lesen der RFID
if (digitalRead(22) == HIGH) { ku_prg = 1; PRG_1_START(); }
if (digitalRead(24) == HIGH) { ku_prg = 2; PRG_2_START(); }
while (ku_prg != 0 ){
while ((micros() - 300000) <= timer_1 ){
for (int i = 1; i <= 11; i ++){
delay(250);
digitalWrite(28, LOW);
delay(250);
ku_prg = 0;
void PRG_1_START(){
display.fillScreen(GREEN);
display.setTextColor(BLACK);
display.setTextSize(5);
display.setCursor(20, 20); display.println("Programm 1 gewählt");
display.setCursor(20, 200); display.println("Sie haben 10 Minuten Zeit,");
display.setCursor(20, 260); display.println("den Startknopf zu drücken.");
timer_1 = micros();
} // Bildschirm Programm 1
void PRG_2_START(){
display.setCursor(20, 20); display.println("Programm 2 gewählt");
timer_1 = micros();
} // Bildschirm Programm 2
void PRG_1(){
t_start = micros();
display.setCursor(10, 10); display.println("Programm 1 gestartet");
if (client.connect(server, 80)) { // if you get a connection, report back via serial:
String str = "insert into WASCHEN (KU_RFID, WA_DATUM, WA_START) values ('" + rfid +"', GETDATE(), CURRENT_TIMESTAMP)"; //rfid.substring(0,8);
str.replace(" ", "%20");
str.replace("'", "%27");
client.println("GET /SQL.aspx?tell=" + str + " HTTP/1.1");
client.println("Host: www.breitenstein.ag");
client.println();
delay(10000);
display.setCursor(10, 10); display.println("Ich warte auf eine Eingabe");
ku_lock = "True";
rfid="";
String str = "update WASCHEN set WA_ENDE = CURRENT_TIMESTAMP WHERE (WA_ID = (select MAX(WA_ID) from WASCHEN))"; //rfid.substring(0,8);
client.println();
void PRG_2(){
display.setCursor(10, 10); display.println("Programm 2 gestartet");
digitalWrite(32, LOW);
digitalWrite(36, HIGH);
digitalWrite(32, HIGH);
digitalWrite(36, LOW);
ku_lock = "True";
rfid="";
void RFID_Check(){
String readString, readString1;
int x=0; //for counting line feeds
char lf=10; //line feed character
String str = "Select%20*%20from%20KUNDE%20where%20(KU_RFID%20='" + rfid.substring(0,8) +"')"; //rfid.substring(0,8);
display.setCursor(0, 0);
display.print("send request to server: "); display.println(client.remoteIP());
client.println("GET /SQL.aspx?ask=" + str + " HTTP/1.1");
client.println();
delay(2000);
display.println("connection failed");
display.print("load file server: "); display.println(client.remoteIP());
client.println("GET /ASK.txt HTTP/1.1");
client.println();
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
if ( c == lf ) {x=x+1;}
if ( x >=10 ) {if ( c != lf) {ku_result += c;}} //building readString
client.stop(); //stop client
//ku_result to single strings
ku_lock = ku_result.substring(0, ku_result.indexOf(" "));
ku_lock.trim();
ku_name = ku_result.substring(ku_result.indexOf(" ")+1);
Serial.println(ku_result);
Serial.println(ku_lock);
Serial.println(ku_name);
ku_result= "";
if (ku_lock == "False"){
display.setCursor(10, 10); display.println("Willkommen");
display.setCursor(10, 50); display.println(ku_name);
display.setCursor(10, 110); display.println("Programme:");
display.setCursor(10, 170); display.println("1 Nur Waschen");
display.setCursor(10, 210); display.println("2 Waschen mit Lift");
display.fillScreen(YELLOW);
display.setCursor(10, 110); display.println("Die Karte ist nicht aktiviert.");
display.setCursor(10, 200); display.println("Melden Sie sich bei unserem");
display.setCursor(10, 250); display.println("Werkstattpersonal.");
/* 10 sekunden warten, dann wieder auf Startbidlschirm */
delay(10000);
ku_lock = "True";
rfid="";
