To do so I have an Arduino Nano, L298N driver, Nema17 Stepper Motor and a PIR sensor.
So far, I can make the motor move to a desired position (door is open) if the PIR senses movement. Then, the motor goes back to the initial position (door is closed).
My problem is that I don't want the motor to move back to initial position if the PIR still sensing movement. For now, with my code, door always go back despite sensing or not sensing movement.
Thanks!!
This is my code
// Include the AccelStepper library:
#include <AccelStepper.h>
// Define the AccelStepper interface type:
#define MotorInterfaceType 4
int PIR = 2;
int mov = 0;
int movAnt;
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(MotorInterfaceType, 8, 9, 10, 11);
// Set the maximum steps per second:
stepper.setMaxSpeed(1000);
// Set speed
stepper.setSpeed(200);
// Set the maximum acceleration in steps per second^2:
stepper.setAcceleration(900);
stepper.setCurrentPosition(0);
pinMode(PIR, INPUT);
int mov = digitalRead(PIR);
if (mov == HIGH){
// Set target position:
stepper.moveTo(1000);
// Run to position with set speed and acceleration:
stepper.runToPosition();
int movAnt = mov;
if (mov == LOW && movAnt == LOW) {
// Move back to original position:
stepper.moveTo(0);
You are declaring a second variable mov inside your if() statement. It has nothing to do with the first declaration (although you might thing they are the same). Just do the assignment. Same is true for movAnt
Also, how to you have it wired up. It may need a pull-up or pull-down resistor
You have to ask yourself and the sensor how long will the sensor continue to indicate movement after it reports movement. Is it just a momentary pulse or will it hold for several seconds after movement is reported?
If just a momentary report, then you may need a different or a secondary sensor to report IR from what ever had been moving.
Yes, I believe this may be my problem. Actually, I expected the sensor to measure constantly. The condition to go back to origin would be not sensing movement during X period of time when door open.
bool DoorOpened = false;
unsigned long openMilli = 0;
int closeDelay = 5000;
unsigned long lastSample = 0;
int intervalSample = 1000;
// Set speed
if (millis() - lastSample >= intervalSample ) {
lastSample = millis();
if (mov == HIGH) {
OpenDoor();
} else
CloseDoor();
void OpenDoor() {
openMilli = millis();
if (!DoorOpened) {
DoorOpened = true;
void CloseDoor() {
if (DoorOpened) {
if (millis() - openMilli >= closeDelay)
DoorOpened = false;
stepper.moveTo(0);
seems good.. ~q
don't like the runToPosition() as it blocks..
could step the close and stop mid swing to reopen..
does the door interrupt the sensor??
you're welcome..
updating the sim still..
got the door closing routine doing a bit more..
swings back open quicker, but gonna play with having a slower closing speed..
can't seem to stop door mid swing..
have fun.. ~q
Yeah, stop the motion if senses movement while closing the door was another feature I considered. Although, the door itself makes the sensor move a bit so... gets a bit hard in the end.
this seems to do just that..
if you can figure out at which steps we start seeing sensor, can try to block out..
int PIR = 2;
int mov = 0;
int movAnt;
// Create a new instance of the AccelStepper class: step ,dir
AccelStepper stepper = AccelStepper(1, 10, 11);
//AccelStepper stepper = AccelStepper(MotorInterfaceType, 8, 9, 10, 11);
byte DoorState = 0;
// Set speed
stepper.setAcceleration(800);
int mov = 0;
if (mov == HIGH) {
OpenDoor();
} else
CloseDoor();
void OpenDoor() {
if (DoorState == 0) {
else {
DoorOpened = false;
stepper.stop();
if (!DoorOpened) {
DoorOpened = true;
DoorState = 0;
// Set speed
void CloseDoor() {
if (DoorOpened) {
switch (DoorState) {
case 0: // Move back to original position:
stepper.setMaxSpeed(500);
// Set speed
stepper.setSpeed(100);
stepper.setAcceleration(400);
stepper.moveTo(0);
DoorState++;
case 1: stepper.run();
if (stepper.currentPosition() == stepper.targetPosition()) {
DoorOpened = false;
