PIR to turn led
This sketch will turn pin4 high correctly, but after the initial high, the led on pin13 toggles on/off at the "pause" rate (5 sec). Would you please advise where the error is?
  if(digitalRead(pirPin) == HIGH){
    digitalWrite(enable,HIGH);
       motor(); //WORKS
        lastMotion = millis();
       digitalWrite(ledPin, HIGH);
       if(lockLow){
         lockLow = false;
         delay(50);
         takeLowTime = true;
     if(digitalRead(pirPin) == LOW){
       digitalWrite(ledPin, LOW);  //the led visualizes the sensors output pin state
       if(takeLowTime){
        lowIn = millis();          //save the time of the transition from high to LOW
        takeLowTime = false;       //make sure this is only done at the start of a LOW phase
       if(!lockLow && millis() - lowIn > pause){
           lockLow = true;
           delay(50);
    motor();
I don't see anything called "pin4".
Any reason for not using "else"?
Should have said the PIR pin which is on pin 4. Instead of a second "if", would "else" be correct?
But pin4 is an input from the PIR?
How does the sketch control it?
When I approach the board, the PIR sensor (on pin 4) reacts as it should; the LED on pin 13 lights but then it flashes on/off every five seconds.
And the value of "pause" is?
Please, just post the whole lot - we can't see what goes on in "motor", and we can't see what all the values are.motor(); //WORKS means not a great deal, unless "WORKS" is defined.
Sorry, I'm not making it easy.
/*______________________________opto switch____________________*/
int switch1 = 5;
int switch2 = 6;
/*_____________________________motor___________________________*/
int randNumberSpeed; // variable to store the random speed value
int randNumberDir;  // variable to store the random direction value
int motorSpeed = 11; // motor speed
int motorDir = 12; // motor direction
long lastMotion;
int enable = 3;
/*----------------------------PIR-------------------------------*/
long unsigned int lowIn;
int calibrationTime = 30;
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 4;    //the digital pin connected to the PIR sensor's output
int ledPin = 13;
/*---------------------------Motor--------------------------------*/
//time = millis();
randomSeed(millis());
pinMode(motorSpeed,OUTPUT);
pinMode(motorDir,OUTPUT);
pinMode(enable,OUTPUT);
/*----------------------------PIR------------------------------*/
  pinMode(pirPin, INPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(pirPin, LOW);
 //give the sensor some time to calibrate
  for(int i = 0; i < calibrationTime; i++){
 /*________________________optoSwitch___________________________*/
pinMode(switch1,INPUT);
pinMode(switch2,INPUT);
/*---------------------------PIR-------------------------------*/
       motor(); //WORKS
       if(lockLow){
         lockLow = false;
         delay(50);
         takeLowTime = true;
       if(takeLowTime){
           lockLow = true;
           delay(50);
    motor();
/*----------------------------Motor---------------------------*/
void motor(){
if (millis() - lastMotion < 10000){
//randomSeed(millis()); // sets millis() as seed
randNumberDir = random(255); // random number from 0-255
analogWrite(motorDir, randNumberDir); // outputs PWM signal
delay(500); // pauses for half a second
randNumberSpeed = random(255); // random number from 0-255
analogWrite(motorSpeed, randNumberSpeed); // outputs PWM signal
//motorStop();
else{
  digitalWrite(motorSpeed,LOW);
  digitalWrite(motorDir,LOW);
  digitalWrite(enable,LOW);
/*_______________________opto switch_______________________________*/
void optoSwitch(){
if(switch1 == HIGH){
  digitalWrite(motorDir,HIGH);
  motor();
if(switch2 == HIGH){
  digitalWrite(motorSpeed,HIGH);
  motor();
