Play audio file under certain light conditions
Good evening everyone,
I am a fine arts student, and I know very little about Arduino, electronics, programming and so on. I therefore ask for help on this forum.
For a university project I need to build the prototype of a device that is able to play - through a speaker - an audio file (3 min pop song) whenever certain light conditions arise (intensity and color temperature of the light; ideally, it would be at sunset / golden hour).
I drafted a first rough project of the elements that I need to make it:
  1. A light source (ideally, it would be the sun, but, in the prototype stage, a dimmable lamp coud be used to simulate the variation of light conditions).
  2. Arduino Uno, breadboard, jumper wires (which I already have),
  3. A light sensor, which has to be capable of detecting the light conditions of the environment in which the device is located. Which one? I found this one ( Amazon.com ) on amazon but I think it can only detect the intensity of the light source and not its color temperature. Can you recommend another one?
  4. An SD card shield, which I'd use to upload the audio file. This one would be ok? Amazon.com
  5. A loudspeaker to play the audio file.
Having said that, I don't really know where to start. Does it make any sense? Is it feasible? Can someone help me / show me tutorials of similar projects? How would you make it?
Thanks in advance for any contribution!
Claudio
Playing the sound file is dead easy: get a DF Player Mini. It's even got a built-in amplifier for your speaker. No need to look further unless you have HiFi requirements.
The light detection is a much harder problem, and where the real work comes in for this project. Colour temperature is based on spectrum, and a regular colour sensor cannot read the spectrum, let alone give you a clue of the colour temperature.
You may be able to get this done with an RGB colour sensor. I expect you to see clear difference between the channel ratio in direct sunlight and a much warmer source of light - such as a dimmed incandescent bulb. Beware of using LEDs: those often do not have a continuous spectrum, though as they're adapted to our eyes as are the RGB sensors this may still work for testing. An old-fashioned incandescent bulb is probably best, as that is guaranteed continuous spectrum.
The really hard part that I see is going to make it perform reliably. Light conditions outdoor vary a lot, far more than we experience as our brains are very good at correcting perceived brightness.
