I don’t know what an object is and i think that is what I’m trying to do. I get this error message when i try to Verify and Compile:
Arduino: 1.0.6 (Mac OS X), Board: “Arduino Uno”
DRUM_SET3:10: error: ‘TMRpcm’ does not name a type
DRUM_SET3.ino: In function ‘void setup()’:
DRUM_SET3:15: error: ‘TMRpcm’ was not declared in this scope
DRUM_SET3.ino: In function ‘void loop()’:
DRUM_SET3:21: error: ‘TMRpcm’ was not declared in this scope
please help my file are attached. All of the files but DRUM_SET3 are libraries I added to my project.
You can't have the name of the object be the same as the type. If you make one of those capital letters lower case that will be enough of a difference. But when you create the class TMRpcm you are essentially making TMRpcm a new keyword. So you can't use it for a variable name anymore.
i tried making it
TMRpcm tmrpcm;
but i still get the error message saying that TMRpcm doesn't name a type.
I changed the files to be libraries in stead of different tabs. i don’t know if this makes a difference.
It makes a big difference. Which libraries folder did you put the files in ? There are two such folders in a standard Arduino installation. What did you name the actual folders that the files are in ?
#include <pcmRF.h>
This form of #include looks first in the system libraries folder for a folder with exactly the same name as the .h file then in the sketches folder libraries folder for the same thing.
#include "pcmRF.h"
This form of #include looks for the named file in the same folder as the sketch.
If you put the files on tabs in the IDE they are stored in the sketch folder.
