Please explain "TCCR1B |= (1 << CS12);"
I realize that this code sets the bit called CS12 in the TCCR1B register.
But I can't find any explanation of why it is coded like that. I would expect the << operator to shift all of the bits in the register to the left but clearly that doesn't happen here.
Perhaps someone can explain it.
...R
The (1<<CS12) creates a temporary operand that contains a 1 in the CS12 position. That temporary is then ORed with the TCCR1B variable(register) setting the CS12 bit and leaving the rest of TCCR1B alone.
KeithRB is correct, but here's a step by step breakdown in case you wanted more detail:
CS12 has a value of 2 since it represents bit 2 of the TCCR1B register.
(1 << CS12) takes the value 1 (0b00000001) and shifts it left 2 times to get (0b00000100).
The order of operations dictates that things in () happen first, so this is done before the "|=" is evaluated.
So now we get TCCR1B |= 0b00000100, which is the same as TCCR1B = TCCR1B | 0b00000100.
Since "|" is "OR", all the bits other than CS12 in TCCR1B are unaffected.
You can do this exact same thing with any of these:
bitSet(TCCR1B, CS12);
TCCR1B |= _BV(CS12);
TCCR1B |= bit(CS12);
I think TCCR1B |= CS12; would work as well, but it's not good practice and may throw a warning.
Thank you for the comprehensive explanation and you also answered my follow-up question
...R
Hillridge:
CS12 is a bit position - a number - not a mask. If it for example, '3', it has the binary value of 0b11, and if you or that with TCCR1B, you will not get the same as the original expression, i.e., CS12 != (1<<CS12) .
