Please help me on this
hello, sorry i tried to read data from arduino to processing ide 4.0.1 but am getting wrong last value on the gauge in display window of processing ide i don't know why it happen that, other 5 values that am getting are fine but the last 6 value is wrong. below is the full processing ide code.
// Import Meter library
import meter.*;
// Import serial library
import processing.serial.*;
Serial serial_port = null;        // the serial port
// serial port buttons
Button btn_serial_up;              // move up through the serial port list
Button btn_serial_dn;              // move down through the serial port list
Button btn_serial_connect;         // connect to the selected serial port
Button btn_serial_disconnect;      // disconnect from the serial port
Button btn_serial_list_refresh;    // refresh the serial port list
String serial_list;                // list of serial ports
int serial_list_index = 0;         // currently selected serial port
int num_serial_ports = 0;          // number of serial ports in the list
Meter m, m2, m3, m4, m5, m6, m7, m8;
void setup(){
  // First we need to create a empty window
  //size(1860, 800); // Size of the window (width, height)
  fullScreen();
  //background(10, 10, 82); // Background color of window (R,G,B)
 // create the buttons
  btn_serial_up = new Button("^", 140, 715, 40, 20);
  btn_serial_dn = new Button("v", 140, 675, 40, 20);
  btn_serial_connect = new Button("Connect", 190, 647, 100, 25);
  btn_serial_disconnect = new Button("Disconnect", 190, 690, 100, 25);
  btn_serial_list_refresh = new Button("Refresh", 190, 730, 100, 25);
  // get the list of serial ports on the computer
  serial_list = Serial.list()[serial_list_index];
  //println(Serial.list());
  //println(Serial.list().length);
  // get the number of serial ports in the list
  num_serial_ports = Serial.list().length;
void mousePressed() {
  // up button clicked
  if (btn_serial_up.MouseIsOver()) {
    if (serial_list_index > 0) {
      // move one position up in the list of serial ports
      serial_list_index--;
  // down button clicked
  if (btn_serial_dn.MouseIsOver()) {
    if (serial_list_index < (num_serial_ports - 1)) {
      // move one position down in the list of serial ports
      serial_list_index++;
  // Connect button clicked
  if (btn_serial_connect.MouseIsOver()) {
    if (serial_port == null) {
      serial_port = new Serial(this, Serial.list()[serial_list_index], 9600);
  // Disconnect button clicked
  if (btn_serial_disconnect.MouseIsOver()) {
    if (serial_port != null) {
      serial_port.stop();
      serial_port = null;
  // Refresh button clicked
  if (btn_serial_list_refresh.MouseIsOver()) {
    // get the serial port list and length of the list
void draw(){
  //background(0, 153, 255); // Background color of window (R,G,B)
  textSize(30);
  fill(255, 255, 255); // Font color , (r,g,b)
  text("TIME:", 320, 712); // ("text", x, y)
  text("DATE:", 600, 712); // ("text", x, y)
  //background(204);
  int time[]={hour(),minute(),second(),day(),month(),year()};
  // Print time on processing console in the format 00 : 00 : 00
  text(nf(time[0],2) + " : " + nf(time[1],2) + " : "+ nf(time[2],2),400,712);
  // Print Date as DD/MM/YYYY
  text(time[3] + " - " + time[4] + " - "+ time[5],681,712);
  // TANK 1
  m = new Meter(this, 2, 51);  // here 25, 10 are x and y coordinates of meter's upper left corner
  m.setTitleFontSize(20);
  m.setTitleFontName("Arial bold");
  m.setTitle("TANK 1 LEVEL(%)");
   // Set a warning if sensor value is too low.
  m.setLowSensorWarningActive(true);
  m.setLowSensorWarningValue((int)10);
  // Set a warning if sensor value is too high.
  m.setHighSensorWarningActive(true);
  m.setHighSensorWarningValue((int)90);
  // Change meter scale values
  String[] scaleLabels = {"0", "10", "20", "30", "40", "50", "60", "70", "80", "90", "100"};
  m.setScaleLabels(scaleLabels);
  m.setScaleFontSize(18);
  m.setScaleFontName("Times new roman bold");
  m.setScaleFontColor(color(200, 30, 70));
  // We can also display the value of meter
  m.setDisplayDigitalMeterValue(true);
  // Lets do some more modifications so our meter looks nice
  m.setArcColor(color(199, 113, 178));
  m.setArcThickness(15);
  m.setMaxScaleValue(100);
  m.setMinInputSignal(0);
  m.setMaxInputSignal(100);
  m.setNeedleThickness(3);
  // TANK 2
  // lets take some refference from first meter
  int mx = m.getMeterX(); // x coordinate of m
  int my = m.getMeterY(); // y coordinate of m
  int mw = m.getMeterWidth();
  m2 = new Meter(this, mx + mw + 20, my);
  m2.setTitleFontSize(20);
  m2.setTitleFontName("Arial bold");
  m2.setTitle("TANK 2 LEVEL(%)");
  m2.setLowSensorWarningActive(true);
  m2.setLowSensorWarningValue((int)10);
  m2.setHighSensorWarningActive(true);
  m2.setHighSensorWarningValue((int)90);
  String[] scaleLabels2 = {"0", "10", "20", "30", "40", "50", "60", "70", "80", "90", "100"};
  m2.setScaleLabels(scaleLabels2);
  m2.setScaleFontSize(18);
  m2.setScaleFontName("Times new roman bold");
  m2.setScaleFontColor(color(200, 30, 70));
  m2.setDisplayDigitalMeterValue(true);
  m2.setArcColor(color(141, 113, 178));
  m2.setArcThickness(15);
  m2.setMaxScaleValue(100);
  m2.setMinInputSignal(0);
  m2.setMaxInputSignal(100);
  m2.setNeedleThickness(3);
  ////WATER TANK 3
  int mx1 = m.getMeterX(); // x coordinate of m
  int my1 = m.getMeterY(); // y coordinate of m
  int mw1 = m.getMeterWidth();
  //m3 = new Meter(this, 250, 400);
   m3 = new Meter(this, mx + mw + 478, my);
  m3.setTitleFontSize(20);
  m3.setTitleFontName("Arial bold");
  m3.setTitle("TANK 3 LEVEL(%)");
  m3.setLowSensorWarningActive(true);
  m3.setLowSensorWarningValue((int)10);
  m3.setHighSensorWarningActive(true);
  m3.setHighSensorWarningValue((int)90);
  String[] scaleLabels3 = {"0", "10", "20", "30", "40", "50", "60", "70", "80", "90", "100"};
  m3.setScaleLabels(scaleLabels3);
  m3.setScaleFontSize(18);
  m3.setScaleFontName("Times new roman bold");
  m3.setScaleFontColor(color(200, 30, 70));
  m3.setDisplayDigitalMeterValue(true);
  m3.setArcColor(color(141, 113, 178));
  m3.setArcThickness(15);
  m3.setMaxScaleValue(100);
  m3.setMinInputSignal(0);
  m3.setMaxInputSignal(100);
  m3.setNeedleThickness(3);
  // TANK 4
  m4 = new Meter(this, 2, 330);  // here 25, 10 are x and y coordinates of meter's upper left corner
  m4.setTitleFontSize(20);
  m4.setTitleFontName("Arial bold");
  m4.setTitle("TANK 4 LEVEL(%)");
  m4.setLowSensorWarningActive(true);
  m4.setLowSensorWarningValue((int)10);
  m4.setHighSensorWarningActive(true);
  m4.setHighSensorWarningValue((int)90);
  String[] scaleLabels4 = {"0", "10", "20", "30", "40", "50", "60", "70", "80", "90", "100"};
  m4.setScaleLabels(scaleLabels4);
  m4.setScaleFontSize(18);
  m4.setScaleFontName("Times new roman bold");
  m4.setScaleFontColor(color(200, 30, 70));
  m4.setDisplayDigitalMeterValue(true);
  m4.setArcColor(color(141, 113, 178));
  m4.setArcThickness(15);
  m4.setMaxScaleValue(100);
  m4.setMinInputSignal(0);
  m4.setMaxInputSignal(100);
  m4.setNeedleThickness(3);
   // TANK 5
  int mx2 = m.getMeterX(); // x coordinate of m
  int my2 = m.getMeterY(); // y coordinate of m
  int mw2 = m.getMeterWidth();
  m5 = new Meter(this, 460, 330);  // here 25, 10 are x and y coordinates of meter's upper left corner
  m5.setTitleFontSize(20);
  m5.setTitleFontName("Arial bold");
  m5.setTitle("TANK 5 LEVEL(%)");
  m5.setLowSensorWarningActive(true);
  m5.setLowSensorWarningValue((int)10);
  m5.setHighSensorWarningActive(true);
  m5.setHighSensorWarningValue((int)90);
  String[] scaleLabels5 = {"0", "10", "20", "30", "40", "50", "60", "70", "80", "90", "100"};
  m5.setScaleLabels(scaleLabels5);
  m5.setScaleFontSize(18);
  m5.setScaleFontName("Times new roman bold");
  m5.setScaleFontColor(color(200, 30, 70));
  m5.setDisplayDigitalMeterValue(true);
  m5.setArcColor(color(141, 113, 178));
  m5.setArcThickness(15);
  m5.setMaxScaleValue(100);
  m5.setMinInputSignal(0);
  m5.setMaxInputSignal(100);
  m5.setNeedleThickness(3);
  // TANK 6
  int mx3 = m.getMeterX(); // x coordinate of m
  int my3 = m.getMeterY(); // y coordinate of m
  int mw3 = m.getMeterWidth();
  m6 = new Meter(this, 920, 330);  // here 25, 10 are x and y coordinates of meter's upper left corner
  m6.setTitleFontSize(20);
  m6.setTitleFontName("Arial bold");
  m6.setTitle("TANK 6 LEVEL(%)");
  m6.setLowSensorWarningActive(true);
  m6.setLowSensorWarningValue((int)10);
  m6.setHighSensorWarningActive(true);
  m6.setHighSensorWarningValue((int)90);
  String[] scaleLabels6 = {"0", "10", "20", "30", "40", "50", "60", "70", "80", "90", "100"};
  m6.setScaleLabels(scaleLabels6);
  m6.setScaleFontSize(18);
  m6.setScaleFontName("Times new roman bold");
  m6.setScaleFontColor(color(200, 30, 70));
  m6.setDisplayDigitalMeterValue(true);
  m6.setArcColor(color(141, 113, 178));
  m6.setArcThickness(15);
  m6.setMaxScaleValue(100);
  m6.setMinInputSignal(0);
  m6.setMaxInputSignal(100);
  m6.setNeedleThickness(3);
  textSize(15);
   if (serial_port != null && serial_port.available()> 0){
    String val = serial_port.readString(); // read incoming string on serial port
    // First we need to separate  values
    String[] list = split(val, ','); // splits value separated by ','
    int tank_1 = int(list[0]); // Tank1
    int tank_2 = int(list[1]);  // Tank2
    int tank_3 = int(list[2]);  // Tank3
    int tank_4 = int(list[3]);  // Tank4
    int tank_5 = int(list[4]);  // Tank5
    int tank_6 = int(list[5]);  // Tank6
    m.updateMeter(int(tank_1)); // int is used due to updateMeter accepts only int values
    m2.updateMeter(int(tank_2));
    m3.updateMeter(int(tank_3));
    m4.updateMeter(int(tank_4));
    m5.updateMeter(int(tank_5));
    m6.updateMeter(int(tank_6));
    println("Water Tank 1 Level: " + tank_1 + " %  " + "Water Tank 2 Level: " + tank_2+ "%"+"Water Tank 3 Level: "+tank_3+ "%"+"Water Tank 4 Level: "+tank_4+ "%"+"Water Tank 5 Level: "+tank_5+ "%" +"Water Tank 6 Level: "+tank_6+ "%");
   // draw the buttons in the application window
  btn_serial_up.Draw();
  btn_serial_dn.Draw();
  btn_serial_connect.Draw();
  btn_serial_disconnect.Draw();
  btn_serial_list_refresh.Draw();
  // draw the text box containing the selected serial port
  DrawTextBox("Select Port", serial_list, 10, 675, 120, 60);
// function for drawing a text box with title and contents
void DrawTextBox(String title, String str, int x, int y, int w, int h)
  fill(255);
  rect(x, y, w, h);
  fill(0);
  textAlign(LEFT);
  textSize(14);
  text(title, x + 10, y + 10, w - 20, 20);
  textSize(12);
  text(str, x + 10, y + 40, w - 20, h - 10);
// button class used for all buttons
class Button {
  String label;
  float x;    // top left corner x position
  float y;    // top left corner y position
  float w;    // width of button
  float h;    // height of button
  // constructor
  Button(String labelB, float xpos, float ypos, float widthB, float heightB) {
    label = labelB;
    x = xpos;
    y = ypos;
    w = widthB;
    h = heightB;
  // draw the button in the window
  void Draw() {
    fill(218);
    stroke(141);
    rect(x, y, w, h, 10);
    textAlign(CENTER, CENTER);
    fill(0);
    text(label, x + (w / 2), y + (h / 2));
  // returns true if the mouse cursor is over the button
  boolean MouseIsOver() {
    if (mouseX > x && mouseX < (x + w) && mouseY > y && mouseY < (y + h)) {
      return true;
    return false;
What about the Arduino code ?
ok sorry let me upload sir
here is a full arduino code sir
int tankValue_1, tankValue_2, tankValue_3, tankValue_4, tankValue_5, tankValue_6;
int tankval1, tankval2, tankval3, tankval4, tankval5, tankval6;
int tank1 = A0;
int tank2 = A1;
int tank3 = A2;
int tank4 = A3;
int tank5 = A4;
int tank6 = A5;
  pinMode(tank1, INPUT);
  pinMode(tank2, INPUT);
  pinMode(tank3, INPUT);
  pinMode(tank4, INPUT);
  pinMode(tank5, INPUT);
  pinMode(tank6, INPUT);
  tankValue_1 = analogRead(tank1);
  tankValue_2 = analogRead(tank2);
  tankValue_3 = analogRead(tank3);
  tankValue_4 = analogRead(tank4);
  tankValue_5 = analogRead(tank5);
  tankValue_6 = analogRead(tank6);
  tankval1 = map(tankValue_1, 686, 255, 0, 100);
  tankval2 = map(tankValue_2, 686, 255, 0, 100);
  tankval3 = map(tankValue_3, 686, 255, 0, 100);
  tankval4 = map(tankValue_4, 686, 255, 0, 100);
  tankval5 = map(tankValue_5, 686, 255, 0, 100);
  tankval6 = map(tankValue_6, 686, 255, 0, 100);
  if(tankval1 < 0)
  tankval1 = 0;
 if(tankval2 < 0)
   tankval2 = 0;
 if(tankval3 < 0)
   tankval3 = 0;
if(tankval4 < 0)
   tankval4 = 0;
 if(tankval5 < 0)
   tankval5 = 0;
if(tankval6 < 0)
   tankval6 = 0;
 if(tankval1 > 100)
  tankval1 = 100;
 if(tankval2 > 100)
   tankval2 = 100;
 if(tankval3 > 100)
   tankval3 = 100;
if(tankval4 > 100)
   tankval4 = 100;
 if(tankval5 > 100)
   tankval5 = 100;
if(tankval6 > 100)
   tankval6 = 100;
  Serial.print(tankval1);
  Serial.print(",");
  Serial.print(tankval2);
  Serial.print(",");
  Serial.print(tankval3);
  Serial.print(",");
  Serial.print(tankval4);
  Serial.print(",");
  Serial.print(tankval5);
  Serial.print(",");
  Serial.print(tankval6);
  delay(200);
any help please
What model Arduino are you using?
What value is tankval6l value and what does processing display?
Is the misread constant or are you getting random readings for a steady value of tankval6?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
am using arduino nano, am reading that value through analog 5 port am getting random values
Hello
Post a schematic to see how we can help.
Just a quick thought, did you try swapping tank6 with another, working tank? Would give you an idea of whether the issue is with software or with hardware / the tank sensors.
i have resolved the problem thank you all
What was the problem ?
it was on the hardware side.
What was the hardware problem?
