I cannot get the serial plotter or the serial monitor to show anything when running a sketch on the R4 Minima which is a genuine part purchased from Mouser last month.
I have searched the forum and elsewhere and tried some suggested fixes.
I am using the Arduino IDE:
Version: 2.3.10
Date: 2026-06-09T16:48:46.639Z
CLI Version: 1.5.1
I reinstalled this today but it did not help.
Uno Rev4 minima connected to ACER Aspire AV15-51 Laptop using a USB type C lead.
The program compiles and uploads successfully
I am running the following program.
pinMode(LED_BUILTIN, OUTPUT);
// I tried some suggested fixes found on the internet
//while(!Serial) { ; } // Stops program from running
delay(1500); // Makes no difference apart from delaying the start
Serial.print("myVariable:");
Serial.print(myVariable);
Serial.print(",");
Serial.print("Constant:");
Serial.println(static_variable);
++myVariable;
if(myVariable> 10) myVariable = 1; // keep the count between 1 and 10
if (!(myVariable % 2)) digitalWrite(LED_BUILTIN, LOW); // turn on LED if myVariable is odd
else digitalWrite(LED_BUILTIN, HIGH); // turn off LED if myVariable is even
delay(100*myVariable); // pause for between 100ms and 1 second
The program is definitely running. The built-in LED is flashing as required by the program.
Nothing shows on either the serial monitor or serial plotter. I have tried many different programs to test the plotter, including examples from the Arduino Forum.
Please see the attached screenshot for details.
I have used a UNO Rev 3 for several years without any problems, but consider myself to be a novice. any help would be most appreciated. Thank you for reading this!
P.S. I just added another suggested fix from this forum, before the Serial.begin() line, as follows:
while (!Serial && (millis()) < 5000) {;};
This did not solve the problem.
