Please help with this avrdude: error
Hi, I'm new to Arduino. I have an error in avrdude and I don't know:
  1. What it is.
  2. How to fix it.
    I am using a trinket with 5v logic from Adafruit and I can't manage to upload my program to it. The code I am trying to upload is unchanged from the code given in a project from Adafruit:
Error:
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, USBtinyISP - Inexpensive USB AVR Programmer
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: error: usbtiny_transmit:
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
I am using a Yoga900 and windows 10 if that is important. The circuit diagram is in the Project Link.
This is very confusing.....
Please help!
Trinket: Adafruit Trinket - Mini Microcontroller - 5V Logic : ID 1501 : $6.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Project: https://goo.gl/A8xpvD
Neopixel Library: http://adafru.it/cDj
Custom Board From: https://adafruit.github.io/arduino-board-index/package_adafruit_index.json
Weasel2:
What are you using for a programmer, and what is the AVRDUDE command line being sent?
(hint you can set your Arduino IDE preferences to "verbose output during compilation" and then copy / paste the part that has the AVRDUDE command string (will be near the end of all the stuff that displays).
I am using USBTinyISP as the programmer.
Also I am not entirely sure what you are asking for. Do you mean this:
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10801 -DARDUINO_AVR_TRINKET3 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\dkopl\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9\variants\tiny8" "C:\Users\dkopl\AppData\Local\Temp\arduino_build_923202\sketch\sketch_mar10a.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10801 -DARDUINO_AVR_TRINKET3 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\dkopl\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9\variants\tiny8" "-IC:\Users\dkopl\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel-master" "C:\Users\dkopl\AppData\Local\Temp\arduino_build_923202\sketch\sketch_mar10a.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Users\dkopl\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel-master\Adafruit_NeoPixel.cpp
Using cached library dependencies for file: C:\Users\dkopl\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel-master\esp8266.c
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10801 -DARDUINO_AVR_TRINKET3 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\dkopl\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9\variants\tiny8" "-IC:\Users\dkopl\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel-master" "C:\Users\dkopl\AppData\Local\Temp\arduino_build_923202\sketch\sketch_mar10a.ino.cpp" -o "C:\Users\dkopl\AppData\Local\Temp\arduino_build_923202\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\dkopl\AppData\Local\Temp\arduino_build_923202\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10801 -DARDUINO_AVR_TRINKET3 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\dkopl\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9\variants\tiny8" "-IC:\Users\dkopl\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel-master" "C:\Users\dkopl\AppData\Local\Temp\arduino_build_923202\sketch\sketch_mar10a.ino.cpp" -o "C:\Users\dkopl\AppData\Local\Temp\arduino_build_923202\sketch\sketch_mar10a.ino.cpp.o"
Weasel2:
Kinda like that, but also upload the sketch to the board (even if it fails). At the very end of that big dump of data, you should see something that looks like this:
[b]avrdude -p atmega2560 -qq -B 8.0 -c wiring -P /dev/ttyACM1 -b 115200 -D -U flash:w:/tmp/build8152949592411684620.tmp/ir_record.cpp.hex:i -U eeprom:w:/tmp/build8152949592411684620.tmp/ir_record.cpp.eep:i[/b]
That's what I was asking for.
Ow ok, but I still don't see what you are talking about. The very end shows thongs relating to avrdude:
this check.
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
But the board is connected and the serial port is on the board.
