I have been working through some of the beginner tutorials and I am running into a problem. I am on project #4 and the project is to have a temperature gauge take a reading and turn on a light depending on the temperature.But it is not even taking a reading, in fact when I plug in the temperature sensor, the lights go dark and when I take out the sensor then all lights turn on. Here is my code:
const int sensorPin = A0;
const float baselineTemp = 20.0;
Serial.begin(9600); // opens a serial port and sets speed to 9600 bits per second
for(int pinNumber = 2; pinNumber<5; pinNumber++) // creates local variable, sets it to 2, tells it to add one each time and stop at 5
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, LOW);
// creates local variable, and calls analogRead() to read the pin AO (line 1) and stores that in variable
int sensorVal = analogRead(sensorPin);
Serial.print("Sensor Value: "); // Prints "Sensor Value"
Serial.print(sensorVal); // and puts in the sensorVal value in
// Converts sensor reading and converts it into voltage
float voltage = (sensorVal/ 1024.0) * 5.0;
Serial.print(" , Volts: ");
Serial.print(voltage);
// Converts the voltage to temp, and sends that to the computer
Serial.print(" , Degrees C: ");
float temperature = (voltage - .5) * 100;// convert the voltage to a temperature in degrees C
Serial.print(temperature);
if(temperature < baselineTemp)
digitalWrite(2, LOW);
digitalWrite(3, LOW); // Turns LEDs off for a low temp
digitalWrite(4, LOW);
else if(temperature >= baselineTemp+2 && temperature <= baselineTemp+4)
digitalWrite(2, HIGH);
digitalWrite(3, LOW); // Turns on 1 LED for a lowish temp
else if(temperature >= baselineTemp+4 && temperature <= baselineTemp+6)
digitalWrite(3, HIGH); // Turns on 2 LEDs for a meduim temp
else if(temperature >= baselineTemp+6)
digitalWrite(3, HIGH); // Turns on all LEDs for a high temp
digitalWrite(4, HIGH);
delay(1);
I was just wondering if you guys could help me find the problem, thanks!
