pls verify the sketch
i am beginner, and i am trying to make a hymidity controller with a relay and DHT11 , my intention is to make relay high if the humidity drops below 70 and continues up to 85 and relay becomes low after 85.
my sketch is given below . pls help me.
#include <dht.h>
dht DHT;
#define DHT11_PIN 7
int pinOut = 8;
void setup(){
pinMode(8, OUTPUT);
int pin0ut = LOW;
int chk = DHT.read11(DHT11_PIN);
Serial.print("Temperature = ");
Serial.println(DHT.temperature);
Serial.print("Humidity = ");
Serial.println(DHT.humidity);
if ((DHT.humidity <70) && (pin0ut == LOW)){
digitalWrite(pinOut, HIGH);
if ((DHT.humidity >85) && (pin0ut == HIGH)){
digitalWrite(pinOut, LOW);
else {
Please read the "How to use this forum" post and carefully follow the directions.
You are comparing pin numbers with HIGH and LOW...
Perhaps you meant
  if (DHT.humidity < 70) {
    digitalWrite (pinOut, HIGH);
  else if (DHT.humidity > 85) {
    digitalWrite (pinOut, LOW);
There no need to avoid writing the same value twice to the same pin, its done all the time.
#include <dht.h>
dht DHT;
#define DHT11_PIN 7
int pinOut = 8;
void setup(){
  pinMode(8, OUTPUT);
int pin0ut = LOW;
  if (DHT.humidity <70) {
   if (DHT.humidity >85){
When humidity drop below 70, relay activate. It deactivate when humidity reach >85. No need for else if you want hysteresis.
Thanks, it was very helpful .it is running perfectly
