Plug and Make Kit
I have a Plug and Make Kit. The first project Thermo and Buttons worked right out of the gate with no problems. I set up the second project Buttons and Movement and the reset the board. The board just stayed resetting itself continually. The instructions said if it didn't work to click the Go to Template again and reload. That did work. Then I set up the third project Buttons and Pixels. The same thing happened as the previous project, so I again went to Go to Template and tried to download but got the error message Not Enough resources. At this point the Arduino is now constantly resetting. At this point I am now stuck.
The hardware i am using in my previous post is the Arduino UNO R4 with Wifi.
Hi @jc7141.
Thanks for your report. I see there is a bug in the code of the template. I have notified the people at Arduino responsible for this code of the problem.
I apologize for the inconvenience this has caused.
Please follow these instructions to correct the code:
  1. Hover the mouse pointer over the code in the box below, then click the icon that looks like two pieces of paper that will appear at the top right hand corner of the box.
    #include "thingProperties.h"
    //Import libraries
    #include <ArduinoGraphics.h>
    #include <Arduino_LED_Matrix.h>
    #include "Arduino_CloudConnectionFeedback.h"
    #include <Modulino.h>
    #include "Button2.h"
    // Creation of objects for Modulino nodes
    ModulinoButtons buttons;
    ModulinoBuzzer buzzer;
    ModulinoPixels pixels;
    ModulinoKnob knob;
    ModulinoDistance distance;
    ModulinoThermo thermo;
    ModulinoMovement movement;
    //Creation of object for UNO R4 WiFi LED Matrix
    ArduinoLEDMatrix matrix;
    //Creation on objects for button handling
    Button2 button0, button1, button2;
    //global varaibles among combinations
    String msg;
    //messages intervals
    unsigned long previousMillis = 0;
    const long interval = 1000;
    bool intro = false, combo = false, desc = false, reset = false;
    unsigned long currentMillis;
    unsigned long connectionTimestamp;
    uint8_t button0StateHandler() {
      buttons.update();
      return buttons.isPressed(0) ? LOW : HIGH;  // fake a normal button -> LOW = pressed
    uint8_t button1StateHandler() {
      buttons.update();
      return buttons.isPressed(1) ? LOW : HIGH;  // fake a normal button -> LOW = pressed
    uint8_t button2StateHandler() {
      buttons.update();
      return buttons.isPressed(2) ? LOW : HIGH;  // fake a normal button -> LOW = pressed
    //making sure the position of the Modulino Knob remains in range
    int position() {
      int pos;
      if (knob.get() % 8 < 0) {
        pos = ((knob.get() % 8) * -1) - 1;
        pos = 7 - (knob.get() % 8);
      return pos;
      // Initialize serial and wait for port to open:
      // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
      delay(1500);
      // Defined in thingProperties.h
      initProperties();
      // Connect to Arduino IoT Cloud
      ArduinoCloud.begin(ArduinoIoTPreferredConnection);
      matrix.begin();
      waitForArduinoCloudConnection(matrix);
         The following function allows you to obtain more information
         related to the state of network and IoT Cloud connection and errors
         the higher number the more granular information you will get.
         The default is 0 (only errors).
         Maximum is 4
      setDebugMessageLevel(2);
      //Animation to inform connection status
      ArduinoCloud.printDebugInfo();
      //Initialisation of the the Modulino nodes
      Modulino.begin();
      if (!buttons.begin()) { Serial.println("Modulino Buttons not found!"); }
      if (!knob.begin()) { Serial.println("Modulino Knob not found!"); }
      if (!buzzer.begin()) { Serial.println("Modulino Buzzer not found!"); }
      if (!pixels.begin()) { Serial.println("Modulino Pixels not found!"); }
      if (!movement.begin()) { Serial.println("Modulino Movement not found!"); }
      if (!thermo.begin()) { Serial.println("Modulino Thermo not found!"); }
      if (!distance.begin()) { Serial.println("Modulino Distance not found!"); }
      //Set the handlers for the Modulino Buttons
      if (buttons) {
        button0.setButtonStateFunction(button0StateHandler);
        button0.setReleasedHandler(handlerBtn0);
        button0.begin(BTN_VIRTUAL_PIN);
        button1.setButtonStateFunction(button1StateHandler);
        button1.setReleasedHandler(handlerBtn1);
        button1.begin(BTN_VIRTUAL_PIN);
        button2.setButtonStateFunction(button2StateHandler);
        button2.setReleasedHandler(handlerBtn2);
        button2.begin(BTN_VIRTUAL_PIN);
      //Set the Modulino Knob as 0 at the beginning
      if (knob) {
        knob.set(0);
      //Initialize the matrix and start the Tetris and heart animation
      matrix.loadSequence(LEDMATRIX_ANIMATION_TETRIS_INTRO);
      matrix.play(false);
      ArduinoCloud.update();
      if (ArduinoCloud.connected() && connectionTimestamp == 0) {
        connectionTimestamp = millis();
      currentMillis = millis();
      // Your code here
      if (matrix.sequenceDone()) {
        //Send first welcome message to message log
        if (intro == false && currentMillis - previousMillis >= interval) {
          msg_log = "Welcome to the Plug and Make kit!";
          intro = true;
        // if Modulino knob and Modulino pixels combo is detected
        if (knob && pixels) {
          //informs the detection
          if (combo == false && currentMillis - previousMillis >= interval) {
            msg_log = "I have found the Modulino Knob + Modulino Pixels";
            combo = true;
          //explains the combo
          if (desc == false && currentMillis - previousMillis >= interval) {
            msg_log = "Using the Modulino Knob:\n-Rotate left or right to change the color on the Modulino pixels and shift the animation on LED Matrix.\n-Give it a press to switch LED color and adjust animation direction.";
            desc = true;
          //suggest to change the Modulino combo
          if (reset == false && currentMillis - previousMillis >= interval * 5) {
            msg_log = "Mix it up!\nSwap Modulinos.\nWhen ready, press reset on board or dashboard.\nGive it a go!";
            reset = true;
          //reset timer
          if (reset && intro && desc && combo) { previousMillis = currentMillis; }
          knobPixels();
          //if Modulino knob and Modulino buzzer combo is detected
        } else if (knob && buzzer) {
            msg_log = "I have found the Modulino Knob + Modulino Buzzer";
            combo = true;
            msg_log = "Let's play with the Modulino Knob! \n-Twist left or right to adjust sound frequency from the buzzer and switch up the animation. \n-Give it a press to mute the buzzer.\nEasy peasy!";
            desc = true;
            reset = true;
          //reset timer
          knobBuzzer();
        } else if (distance && pixels) {
            msg_log = "I have found the Modulino Distance + Modulino Pixels";
            combo = true;
            msg_log = "Try this:\nHover your hand over Modulino Distance and see Modulino Pixels react to your hand's distance.\nSee distance values in centimeters on UNO R4 WiFi LED matrix.\nGive it a try and see the magic happen!";
            desc = true;
            reset = true;
          //reset timer
          distancePixels();
        } else if (buttons && thermo) {
            msg_log = "I have found the Modulino Buttons + Modulino Thermo";
            combo = true;
            msg_log = "Let's explore Modulino Buttons! \nTwo LEDs show which buttons to press. \nButton A displays temp on UNO R4 WiFi LED matrix, Button C shows humidity. \nGive it a try!";
            desc = true;
            reset = true;
          //reset timer
          thermoButtons();
        } else if (buttons && pixels) {
            msg_log = "I have found the Modulino Buttons + Modulino Pixels";
            combo = true;
            msg_log = "Enjoy this 2-player game! You're Player 1 (Red), your friend's Player 2 (Green) on Modulino Pixels. Tap A to move Player 1, C for Player 2. Goal? Reach the end fast to score. First to 9+ points wins! Ready, set,    go!";
            desc = true;
            reset = true;
          //reset timer
          buttonsPixels();
        } else if (buttons && movement) {
            msg_log = "I have found the Modulino Buttons + Modulino Movement";
            combo = true;
            msg_log = "Use Modulino Movement to guide your character at the LED Matrix bottom. Press button B on Modulino Button to smash targets atop. Let's conquer!";
            desc = true;
            reset = true;
          //reset timer
          movementButton();
          //No Modulino found
            msg_log = "I haven't found any Modulino combinations ";
            combo = true;
            msg_log = "Looks like no Modulino combination is connected right now. Don't worry!\nMake sure the Modulino nodes are properly connected and reset the board.\nIf you need more help, find more information at arduino.cc/   plug-and-make-kit.";
            desc = true;
          matrix.beginDraw();
          matrix.stroke(0xFFFFFFFF);
          matrix.textScrollSpeed(80);
          const char text[] = "    Connect a Modulino combination!";
          matrix.textFont(Font_5x7);
          matrix.beginText(0, 1, 0xFFFFFF);
          matrix.println(text);
          matrix.endText(SCROLL_LEFT);
          matrix.endDraw();
        //clear message log while the tetris animation is playing
        msg_log = PropertyActions::CLEAR;
        //reset timer
    MODULINO BUZZER + MODULINO KNOB COMBINATION
    int frameDuration = 50;
    byte frame[8][12];
    void knobBuzzer() {
      //call wave function to paint in the LED matrix (functiond defined at the bottom)
      advanceWaveform();
      matrix.renderBitmap(frame, 8, 12);
      delay(frameDuration);
      //control Modulino buzzzer with Modulino Knob position
      if (knob.isPressed()) {
        buzzer.noTone();
        buzzer.tone(map(position(), 8, 0, 200, 440), 250);
    void advanceWaveform() {
      for (int y = 0; y <= 7; y++) {
        for (int x = 0; x <= 11 - 1; x++) {
          if (frame[y][x + 1] == 1) {
            frame[y][x] = 1;
            frame[y][x + 1] = 0;
            frame[y][x] = 0;
      frame[position()][11] = 1;
    MODULINO DISTANCE + MODULINO PIXELS COMBINATION
    float dist = 0;
    void distancePixels() {
      if (distance.available()) {
        dist = distance.get();
        int numPixels = map(dist, 400, 20, 8, 0);
        pixels.clear();
        for (int i = 0; i < numPixels; i++) {
          pixels.set(i, 0, 255, 0, 5);
        pixels.show();
        delay(1);
      matrix.beginDraw();
      char text[4];
      String msg;
      msg = String(dist / 10);
      msg.toCharArray(text, 4);
      matrix.textFont(Font_4x6);
      matrix.beginText(1, 1, 0xFFFFFF);
      matrix.endText();
      matrix.endDraw();
    MODULINO BUTTONS + MODULINO PIXELS COMBINATION
    int player1 = 0, player2 = 0;
    int scorePlayer1 = 0;
    int scorePlayer2 = 0;
    bool winning = false;
    int maxScore = 9;
    void handlerBtn0(Button2& btn) {
      player1 = (player1 + 1);
    void handlerBtn2(Button2& btn) {
      player2 = (player2 + 1);
    void buttonsPixels() {
      //call handler for Button A and Button C on Modulino Buttons
      button0.loop();
      button2.loop();
      //when the player reach the end add one in the score
      if (player1 == 8) {
        player1 = 0;
        player2 = 0;
        scorePlayer1 += 1;
      if (player2 == 8) {
        player1 = 0;
        player2 = 0;
        scorePlayer2 += 1;
      // if player 1 wins
      if (scorePlayer1 > maxScore) {
        for (int i = 0; i < 8; i++) {
          pixels.set(i, 255, 0, 0, 5);
        pixels.show();
        matrix.beginDraw();
        matrix.textScrollSpeed(70);
        char text[19];
        msg = "   Player 1 wins!";
        msg.toCharArray(text, 17);
        matrix.endDraw();
        winning = true;
      } else if (scorePlayer2 > maxScore) {
        //if player 2 wins
        pixels.show();
        matrix.beginDraw();
        char text[19];
        msg = "   Player 2 wins!";
        matrix.endDraw();
        winning = true;
        // THE GAME !!!
        buttons.setLeds(true, false, true);
        pixels.clear();
        pixels.set(player1, 255, 0, 0, 10);
        pixels.set(7 - player2, 0, 255, 0, 10);
        pixels.show();
        matrix.beginDraw();
        char text[4];
        msg = String(scorePlayer1) + "-" + String(scorePlayer2);
        matrix.endText();
      // Initialize all to start the game again
      if (winning) {
        winning = false;
        player1 = 0;
        player2 = 0;
        scorePlayer2 = 0;
        scorePlayer1 = 0;
    MODULINO KNOB + MODULINO PIXELS COMBINATION
    void knobPixels() {
      //Paint diagonal lines pattern on the LED Matrix
      matrix.beginDraw();
        for (int j = 0; j < 12; j++) {
          matrix.set(j, i, 0, 0, 0);
        for (int i = -11; i < 25; i += 3) {
          matrix.line(i + knob.get() % 8, 0, i + (5 + (knob.get() % 8)), 7);
          matrix.line(i - knob.get() % 8, 0, i - (5 + (knob.get() % 8)), 7);
      matrix.endDraw();
      pixels.clear();
        // if the Modulino Knob is pressed, only one LED is on and it is controlled by the rotation of the knob
        pixels.set(position(), VIOLET, 10);
        //pain a rainbow patter on the LEDs, the rotation on the Modullino Knob moves the color according to the HUE wheel
          int redValue, greenValue, blueValue;
          int hue = (knob.get() * 20) % 360;
          hueToRGB((hue + i * 45) % 360, redValue, greenValue, blueValue);
          pixels.set(i, redValue, greenValue, blueValue, 10);
      pixels.show();
    void hueToRGB(int hue, int& r, int& g, int& b) {
      float s = 1.0, v = 1.0;  // Full saturation and value
      int i;
      float f, p, q, t;
      hue = hue % 360;  // Ensure hue is within 0-360
      float h = hue / 60.0;
      i = floor(h);
      f = h - i;
      p = v * (1.0 - s);
      q = v * (1.0 - s * f);
      t = v * (1.0 - s * (1.0 - f));
      switch (i) {
        case 0:
          r = v * 255;
          g = t * 255;
          b = p * 255;
        case 1:
          r = q * 255;
          g = v * 255;
          b = p * 255;
        case 2:
          r = p * 255;
          g = v * 255;
          b = t * 255;
        case 3:
          r = p * 255;
          g = q * 255;
          b = v * 255;
        case 4:
          r = t * 255;
          g = p * 255;
          b = v * 255;
        default:
          r = v * 255;
          g = p * 255;
          b = q * 255;
    MODULINO MOVEMENT + MODULINO BUTTONS COMBINATION
    bool shoot = false;
    int currentShootY = 8;
    unsigned long previousShootMillis = 0;
    unsigned long previousTimerMillis = 0;
    const long shootInterval = 50;  // Shooting animation speed
    const long timerInterval = 20000;
    int shootpos;
    int targetPosX = 3, targetPosY = 2;
    bool start = false, game = false;
    int timeLine = 0;
    float valX;
    void handlerBtn1(Button2& btn) {
      shoot = true;
      shootpos = valX;
    float mapF(float x, float in_min, float in_max, long out_min, long out_max) {
      return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    void movementButton() {
      //call button B handler
      button1.loop();
      //update values in Modulino Movement
      movement.update();
      //set the LEDson the Modulino buttons so only button B is on
      buttons.setLeds(false, true, false);
      //Map the values of X between 0 to 12
      valX = mapF(movement.getX(), -1.2, 1.2, 12, 0);
      //Before start, set the timer 0 and clean the score
      if (!start) {
        previousTimerMillis = currentMillis;
        scorePlayer1 = 0;
        start = true;
      if (start) {
        //Start the game, which last as long as timerInterval
        if (currentMillis - previousTimerMillis < timerInterval) {
          // Handle shooting logic
          if (shoot && currentShootY >= 0) {
            if (currentMillis - previousShootMillis > shootInterval) {
              previousShootMillis = currentMillis;  // Update the last shooting time
              currentShootY--;
            if (shootpos == targetPosX && currentShootY <= targetPosY + 1) {
              scorePlayer1++;
              targetPosX = random(2, 10);
              currentShootY = 8;
              shoot = false;
          } else if (shoot) {
            currentShootY = 8;
            shoot = false;
          // Drawing the game state
          matrix.beginDraw();
          //Draw character
          matrix.point(valX, 6);
          matrix.line(valX - 1, 7, valX + 1, 7);
          //Draw target
          matrix.point(targetPosX, targetPosY);
          //Draw bullet
          matrix.point(shootpos, currentShootY);
          timeLine = map(currentMillis - previousTimerMillis, 0, timerInterval, 10, 0);
          matrix.line(0, 0, timeLine, 0);
          matrix.endDraw();
        } else if (currentMillis - previousTimerMillis >= timerInterval && currentMillis - previousTimerMillis < timerInterval + 3000) {
          // Handle score display, it displays for 3 seconds
          msg = String(scorePlayer1);
          matrix.beginDraw();
          char text[3];
          msg.toCharArray(text, 3);
          matrix.beginText(3, 1, 0xFFFFFF);
          matrix.endText();
          matrix.endDraw();
        } else if (currentMillis - previousTimerMillis >= timerInterval + 3000) {
          //Clean the screen and restart the game after the 3 seconds of displaying the score
          matrix.beginDraw();
          matrix.endDraw();
          start = false;
    MODULINO THERMO + MODULINO BUTTONS COMBINATION
    int select = 1;
    void thermoButtons() {
      //update data coming from Modulino Buttons
      buttons.update();
      //Set LEDs on Modulino Buttons
      if (buttons.isPressed(0)) {
        select = 1;
      if (buttons.isPressed(2)) {
        select = 3;
      if (select == 1) {
        msg = String(thermo.getTemperature()).substring(0, 2) + "C";
      } else if (select == 3) {
        msg = String(thermo.getHumidity()).substring(0, 2) + "%";
      matrix.beginDraw();
      char text[5];
      msg.toCharArray(text, 5);
      matrix.endText();
      matrix.endDraw();
      Since ResetBoard is READ_WRITE variable, onResetBoardChange() is
      executed every time a new value is received from IoT Cloud.
    void onResetBoardChange() {
      // Add your code here to act upon ResetBoard change
      if (millis() - connectionTimestamp > 5000) {  // Ignore spurious callback that occurs on startup after reset.
        matrix.beginDraw();
        const char text[] = "  Resetting!  ";
        matrix.endDraw();
        NVIC_SystemReset();
      Since MsgLog is READ_WRITE variable, onMsgLogChange() is
    void onMsgLogChange() {
      // Add your code here to act upon MsgLog change
  2. Click the following link to open the list of your Arduino Cloud IoT Things in your web browser:
    https://app.arduino.cc/things
  3. Find the Thing that was created by the active "Plug and Make Getting Started" template in the list on the page.
    This will be the one that has an item shown under the "Device" column.
  4. Click on the entry for the Thing for the active template.
    The Thing page will open.
  5. Select the "Sketch" tab at the top of the page.
    The Thing sketch will open in Arduino Cloud Editor.
  6. Click on the Thing sketch code you will see in the editor panel of the Arduino Cloud Editor page.
  7. Press the Ctrl+A keyboard shortcut (Command+A if you are using macOS).
    All the code will be selected.
  8. Press the Ctrl+V keyboard shortcut (Command+V if you are using macOS).
    This will replace the selected code with the corrected code you copied at step 1 of these instructions.
  9. Click the ➜ button ("Upload") on the toolbar at the top of Arduino Cloud Editor.
    An upload of the corrected sketch to your UNO R4 WiFi board will start.
  10. Wait for the upload operation to finish successfully.
You should now be able to go back to using the project as you were before without encountering the problem of the board getting stuck in the endless reset loop.
Please let me know if you have any questions or problems while following those instructions.
In case you are interested, here is the fix I applied to the code:
--- a/plug-make-getting-started/plug-make-getting-started.ino
+++ b/plug-make-getting-started/plug-make-getting-started.ino
@@ -29,6 +29,8 @@ const long interval = 1000;
+unsigned long connectionTimestamp;
   buttons.update();
@@ -106,6 +108,10 @@ void setup() {
+  if (ArduinoCloud.connected() && connectionTimestamp == 0) {
+    connectionTimestamp = millis();
   // Your code here
@@ -669,18 +675,19 @@ void thermoButtons() {
+  if (millis() - connectionTimestamp > 5000) {  // Ignore spurious callback that occurs on startup after reset.
+    matrix.beginDraw();
+    matrix.stroke(0xFFFFFFFF);
+    matrix.textScrollSpeed(80);
+    const char text[] = "  Resetting!  ";
+    matrix.textFont(Font_5x7);
+    matrix.beginText(0, 1, 0xFFFFFF);
+    matrix.println(text);
+    matrix.endText(SCROLL_LEFT);
+    matrix.endDraw();
-  matrix.beginDraw();
-  matrix.stroke(0xFFFFFFFF);
-  matrix.textScrollSpeed(80);
-  const char text[] = "  Resetting!  ";
-  matrix.textFont(Font_5x7);
-  matrix.beginText(0, 1, 0xFFFFFF);
-  matrix.println(text);
-  matrix.endText(SCROLL_LEFT);
-  matrix.endDraw();
-  NVIC_SystemReset();
+    NVIC_SystemReset();
The reason for this is that the "Free" Arduino Cloud plan has a limit of two Arduino Cloud IoT Things. A new Thing is created each time you use the Template. This is why you were able to use the Template a second time to work around the reset bug, but not a third time.
You won't need to use that workaround any more after fixing the bug in the code, so this won't be a problem going forward.
I have resolved the problem with the resource error. I am new and using the free version. I was not aware of the Thing limit of 2. When I tried to load the template a third time I was exceeding the Free limit of 2. No further action is needed since when I deleted one of the old Things everything started working without any problems.
I have merged your other post on the same subject @jc7141.
In the future, please only create one topic for each distinct subject matter. When you want to add additional information to your existing topic, or respond to what others wrote there, just click the "Reply" button at the bottom of the existing topic.
Thanks in advance for your cooperation.
