point de rosée pour astronomie
alors, vendredi soir, test en live à blanc pour valider les affichages.
ca le fait, mais il faut que je modifie encore certaines choses.
le code est brut de pomme, mais tout est opérationnel
#include <DHT.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
Adafruit_BMP085 bmp;
#define DHTTYPE DHT22
#define DHTPIN A1
DHT dht(DHTPIN, DHTTYPE);
#include "LCD4884.h"
#include "DFrobot_bmp.h"
#include "DFrobot_chinese.h"
//keypad debounce parameter
#define DEBOUNCE_MAX 15
#define DEBOUNCE_ON  10
#define DEBOUNCE_OFF 3
#define NUM_KEYS 5
#define NUM_MENU_ITEM	5
// joystick number
#define LEFT_KEY 0
#define CENTER_KEY 1
#define DOWN_KEY 2
#define RIGHT_KEY 3
#define UP_KEY 4
// menu starting points
#define MENU_X	10
#define MENU_Y	1
int  adc_key_val[5] ={
  50, 200, 400, 600, 800 };
// debounce counters
byte button_count[NUM_KEYS];
// button status - pressed/released
byte button_status[NUM_KEYS];
// button on flags for user program
byte button_flag[NUM_KEYS];
// menu definition
char menu_items[NUM_MENU_ITEM][12]={
  "TEMPERATURE",
  "HYGROMETRIE",
  "ALTITUDE",
  "POINT_ROSEE",
  "VENTILO"
void (*menu_funcs[NUM_MENU_ITEM])(void) = {
  temperature,
  hygrometrie,
  altitude,
  about,
  ventilo
char current_menu_item;
#define led 13
#define led1 12
#define chauffage 11
  int pointrosee ;
  char pointroseeBuf[8];
  int temp ;
  char tempBuf[8];
  int hum ;
  char humBuf[8];
pinMode(led,OUTPUT);
pinMode(led1,OUTPUT);
pinMode(chauffage, OUTPUT);
  // setup interrupt-driven keypad arrays
  // reset button arrays
  for(byte i=0; i<NUM_KEYS; i++){
    button_count[i]=0;
    button_status[i]=0;
    button_flag[i]=0;
  // Setup timer2 -- Prescaler/256
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
  TCCR2B &= ~(1<<WGM22);
  TCCR2B = (1<<CS22)|(1<<CS21);
  ASSR |=(0<<AS2);
  // Use normal mode
  TCCR2A =0;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= (0<<OCIE2A);
  TCNT2=0x6;  // counting starts from 6;
  TIMSK2 = (1<<TOIE2);
  SREG|=1<<SREG_I;
  lcd.LCD_init();
  lcd.LCD_clear();
  //menu initialization
  init_MENU();
  current_menu_item = 0;
  lcd.backlight(ON);//Turn on the backlight
  //lcd.backlight(OFF); // Turn off the backlight
      dht.begin();
  // Sensor init
 if (!bmp.begin()) {
  Serial.println("No valid BMP085 sensor found!");
  while (true) {}
  analogWrite(chauffage,0);
  byte i;
  for(i=0; i<NUM_KEYS; i++){
    if(button_flag[i] !=0){
      button_flag[i]=0;  // reset button flag
      switch(i){
      case UP_KEY:
        // current item to normal display
        lcd.LCD_write_string(MENU_X, MENU_Y + current_menu_item, menu_items[current_menu_item], MENU_NORMAL );
        current_menu_item -=1;
        if(current_menu_item <0)  current_menu_item = NUM_MENU_ITEM -1;
        // next item to highlight display
        lcd.LCD_write_string(MENU_X, MENU_Y + current_menu_item, menu_items[current_menu_item], MENU_HIGHLIGHT );
      case DOWN_KEY:
        current_menu_item +=1;
        if(current_menu_item >(NUM_MENU_ITEM-1))  current_menu_item = 0;
      case LEFT_KEY:
        init_MENU();
      case CENTER_KEY:
        lcd.LCD_clear();
        (*menu_funcs[current_menu_item])();
        lcd.LCD_clear();
        init_MENU();
lecture();
  while(tempBuf == pointroseeBuf || hum > 90 ){
    lecture();
digitalWrite(led,1);
digitalWrite(led1,0);
analogWrite(chauffage,255);
lcd.LCD_write_string(10, 1, tempBuf, MENU_NORMAL);
  lcd.LCD_write_string(10, 2, humBuf, MENU_NORMAL);
 //   lcd.LCD_write_string(38, 5, "OK", MENU_HIGHLIGHT );
// waitfor_OKkey();
digitalWrite(led,0);
digitalWrite(led1,1);
/* menu functions */
void init_MENU(void){
  byte i;
  lcd.LCD_clear();
  lcd.LCD_write_string(MENU_X, MENU_Y, menu_items[0], MENU_HIGHLIGHT );
  for (i=1; i<NUM_MENU_ITEM; i++){
    lcd.LCD_write_string(MENU_X, MENU_Y+i, menu_items[i], MENU_NORMAL);
// waiting for center key press
void waitfor_OKkey(){
  byte i;
  byte key = 0xFF;
  while (key!= CENTER_KEY){
        if(i== CENTER_KEY) key=CENTER_KEY;
void temperature()
    float t = dht.readTemperature();
     char tempBuf[6]="";
  sprintf(tempBuf, "%d",(int)t);
    lcd.LCD_write_string_big(10, 1,tempBuf, MENU_NORMAL);
  lcd.LCD_write_string(78, 2, "C", MENU_NORMAL);
  waitfor_OKkey();
void hygrometrie(){
    float h = dht.readHumidity();
  char humBuf[6];
  sprintf(humBuf, "%d",(int)h);
    lcd.LCD_write_string_big(10, 1,humBuf, MENU_NORMAL);
  lcd.LCD_write_string(78, 2, "%", MENU_NORMAL);
  waitfor_OKkey();
void altitude(){
     int pression = bmp.readAltitude();
  char pressionBuf[8];
  sprintf(pressionBuf, "%d",pression);
  lcd.LCD_write_string_big(1, 1,pressionBuf, MENU_NORMAL);
  lcd.LCD_write_string(78, 2, "M", MENU_NORMAL);
  waitfor_OKkey();
void about(){
  int point_rosee = dewPoint(t, h);
  char point_roseeBuf[8];
  sprintf(point_roseeBuf, "%d",point_rosee);
    int point_rosee_fast = dewPointFast(t, h);
  char point_rosee_fastBuf[8];
  sprintf(point_rosee_fastBuf, "%d",point_rosee_fast);
    lcd.LCD_write_string( 0, 20, point_rosee_fastBuf, MENU_NORMAL);
  lcd.LCD_write_string( 15, 20, "C", MENU_NORMAL);
    lcd.LCD_write_string( 23, 20, "PR Fast", MENU_NORMAL);
    lcd.LCD_write_string( 0, 1, point_roseeBuf, MENU_NORMAL);
  lcd.LCD_write_string( 15, 1, "C", MENU_NORMAL);
    lcd.LCD_write_string( 23, 1, "P.rosee", MENU_NORMAL);
  waitfor_OKkey();
void ventilo(){
   lcd.LCD_write_string(0, 1,"Ventilo", MENU_NORMAL);
analogWrite(chauffage, 255);
  waitfor_OKkey();
// The followinging are interrupt-driven keypad reading functions
// which includes DEBOUNCE ON/OFF mechanism, and continuous pressing detection
// Convert ADC value to key number
char get_key(unsigned int input)
  char k;
  for (k = 0; k < NUM_KEYS; k++)
    if (input < adc_key_val[k])
      return k;
  if (k >= NUM_KEYS)
    k = -1;     // No valid key pressed
  return k;
void update_adc_key(){
  int adc_key_in;
  char key_in;
  byte i;
  adc_key_in = analogRead(0);
  key_in = get_key(adc_key_in);
    if(key_in==i)  //one key is pressed
      if(button_count[i]<DEBOUNCE_MAX)
        button_count[i]++;
        if(button_count[i]>DEBOUNCE_ON)
          if(button_status[i] == 0)
            button_flag[i] = 1;
            button_status[i] = 1; //button debounced to 'pressed' status
    else // no button pressed
      if (button_count[i] >0)
        button_flag[i] = 0;
        button_count[i]--;
        if(button_count[i]<DEBOUNCE_OFF){
          button_status[i]=0;   //button debounced to 'released' status
// Timer2 interrupt routine -
// 1/(160000000/256/(256-6)) = 4ms interval
ISR(TIMER2_OVF_vect) {
  TCNT2  = 6;
  update_adc_key();
double dewPoint(double t, double h)
        // (1) Saturation Vapor Pressure = ESGG(T)
        double RATIO = 373.15 / (273.15 + t);
        double RHS = -7.90298 * (RATIO - 1);
        RHS += 5.02808 * log10(RATIO);
        RHS += -1.3816e-7 * (pow(10, (11.344 * (1 - 1/RATIO ))) - 1) ;
        RHS += 8.1328e-3 * (pow(10, (-3.49149 * (RATIO - 1))) - 1) ;
        RHS += log10(1013.246);
        // factor -3 is to adjust units - Vapor Pressure SVP * humidity
        double VP = pow(10, RHS - 3) * h;
        // (2) DEWPOINT = F(Vapor Pressure)
        double T = log(VP/0.61078);   // temp var
        return (241.88 * T) / (17.558 - T);
// delta max = 0.6544 wrt dewPoint()
// 6.9 x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double t, double h)
        double a = 17.271;
        double b = 237.7;
        double temp = (a * t) / (b + t) + log(h*0.01);
        double Td = (b * temp) / (a - temp);
        return Td;
void lecture(){
   pointrosee = dewPoint(t, h);
  sprintf(pointroseeBuf, "%d",pointrosee);
   temp = dht.readTemperature();
  char tempBuf[8];
  sprintf(tempBuf, "%d",temp);
   hum = dht.readHumidity();
  char humBuf[8];
  sprintf(humBuf, "%d",hum);
Bonsoir,
@infobarquee. Si tu mets ton code entre des balises Code (#) plutôt que balises Quote, le tout sera plus lisible.
:wink:
oups, modifié :wink:
faut que j'aille me coucher je crois :grin:
