Pointer to Member Function
I'm not sure how to use pointers to member functions.
I am declaring it in the example class like this:
void (FanSpeed::*ISR_callback)()  = &FanSpeed::handleInterrupt;
where handleInterrupt() is a member function that I am trying to initialize an ISR like this (doesn't compile):
attachInterrupt(digitalPinToInterrupt(irq_pin), this->ISR_callback, value);
I get this error:
FanClassTest.ino: In member function 'void FanSpeed::setup(uint8_t, int)':
FanClassTest.ino:25:76: error: cannot convert 'void (FanSpeed::*)()' to 'void (*)()' for argument '2' to 'void attachInterrupt(uint8_t, void (*)(), int)'
Error compiling.
Full Code:
// CLASS DEFINITION
class FanSpeed {
  public:
    FanSpeed() {};
    void
      setup(uint8_t irq_pin, int value),
      handleInterrupt(void);
    double
      getSpeed();
    void (FanSpeed::*ISR_callback)()  = &FanSpeed::handleInterrupt;  //<<<<<<< member function pointer
  private:
    uint32_t
      _lastMicros = 0UL,
      _interval = 60000000UL;
void FanSpeed::setup(uint8_t irq_pin, int value)
  attachInterrupt(digitalPinToInterrupt(irq_pin), this->ISR_callback, value);  // trying to pass a pointer to the member function to attachInturrupt
inline void FanSpeed::handleInterrupt(void)
  uint32_t nowMicros = micros();
  _interval = nowMicros - _lastMicros;
  _lastMicros = nowMicros;
double FanSpeed::getSpeed()
  if (micros() - _lastMicros < 4294967296UL) // has rotated in the last ~70 seconds
    return 60000000.0 / _interval;
    return 0;
// PROGRAM START
FanSpeed* fan1;
uint8_t fan1pin = 2;
  pinMode(fan1pin, INPUT_PULLUP);
  fan1 = new FanSpeed();
  fan1-> setup(fan1pin, FALLING);
  static uint32_t lastMillis = 0;
  if (millis() - lastMillis > 1000UL)
    Serial.print(F("Fan one speed = ")); Serial.print(floor(fan1->getSpeed() + 0.5), 0);Serial.println(F(" RPM"));
    Serial.print('\r');
    lastMillis = millis();
Easy, you can't, unless the function is declared static. If you need to call a member function as part of an ISR you have to either make that function static (in which case, you better not ever create more than one instance of the object), or set the ISR to a non-member function that CALLs the member function through it's object.
Regards,
Ray L.
RayLivingston:
Regards,
Ray L.
I see...
I had this, but wanted not to have to mess about with the creation of the function prototypes:
// CLASS DEFINITION
class FanSpeed {
  public:
    void
      setup(uint8_t irq_pin, void (*ISR_callback)(void), int value),
    double
      getSpeed();
  private:
    uint32_t
      _lastMicros = 0UL,
void FanSpeed::setup(uint8_t irq_pin, void (*ISR_callback)(void), int value)
  attachInterrupt(digitalPinToInterrupt(irq_pin), ISR_callback, value);
    return 0;
// PROGRAM START
FanSpeed* fan1;
FanSpeed* fan2;
uint8_t fan2pin = 3;
// functon prototypes
void fan1InterruptHandler(void)
  fan1->handleInterrupt();
void fan2InterruptHandler(void)
  fan2->handleInterrupt();
  pinMode(fan2pin, INPUT_PULLUP);
  fan1-> setup(fan1pin, fan1InterruptHandler, FALLING);
  fan2 = new FanSpeed();
  fan2-> setup(fan2pin, fan2InterruptHandler, FALLING);
    Serial.print(F("Fan two speed = ")); Serial.print(floor(fan2->getSpeed() + 0.5), 0);Serial.println(F(" RPM"));
    Serial.print('\r');
yeah, @PaulS taught me that way when I was learning callbacks, but I was wondering if it could be brought along further.
Thanks!
Calling an ISR from a class
