I've implemeted some sort of digital signal generator on a uno and nano every and it works quite well. When I try to optimise stuff I get some problems though.
1.) My digi out pins are on both PORTB and PORTD so in my loop i have to differentiate.
Instead of doing something like
It would be much nicer to have a pointer to PORTB or D and just write on *pPort...
Now I did quite some research and found many examples like
volatile uint_t * const pPort = &PORTD;
But, well, I don't know if that ever worked, but it definitely doe not work for me, it keeps telling me "cannot convert 'PORTDClass*' to 'volatile byte* {aka volatile unsigned char*}' in initialization". (or something similar, no standard type works for me)
Now I could define a PORTDClass* pPort but that does not work when writing on PORTB...
Is there any way?
2.) I want to toggle a PIN by doing a PORTB ^= bitMask; No chance: no match for 'operator^=' (operand types are 'PORTBClass' and 'char')
Ok, so the = operator is overloaded but ^= is not, fine, but PORTB = PORTB ^ bitMask gives a similar error msg. What is funny about this is this arduino reference page ^ - Arduino-Referenz that at the bottom tells me PORTB = PORTB ^ bitMask should be ok.
If you're "optimizing", you might want to check whether using the pointer is actually faster than using the if. Pointers to io registers are not particularly fast on AVRs.
Also, you can invert port pins on most AVRs by writing to the PIN register:
if (PinOut[I].portID == 0) PINB = 0x25; // invert some bits
else PIND = 0x25; // invert bits in OTHER port.
(which avoids the atomicity issue gfvalvo likes to bring up...)
Thanks for the input. Yeah, "optimising" might make it worse...
Anyhow, exactly this line above gives me a "error: cannot convert 'PORTBClass*' to 'volatile uint8_t* {aka volatile unsigned char*}' in initialization volatile uint8_t *ptr = &PORTB;"
volatile uint8_t ptr = PORTB; doesn't work either.
Is there a compile switch or something I'd have to set?
Doing anything with PINB gives me a "'PINB' was not declared in this scope"
Ah.. nano every doesn’t have “ports” - it has PORT simulation...
Edit: Not a complete statement.
You can turn the "Registers Emulation" off in the tools menu (and you should probably do so, if you are at all concerned with efficiency. Also, it looks like it's supposed to do mapping from the (relatively logical) ATmeg328p pins to the (scrambledish) 4809 boards.
This would change the definition of PORTB from 'PORTBClass*' to '*(PORT_t *)', which still won't behave the way it does on the older AVRs.
You have two choices. One is the VPORTs, which behave like the old ports, more or less.
You'd want something like:
