Poolsteuerung mit Arduino
Toll ... immer gegen die Deutschen ... :wink:
#include <VirtualWire.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#define RX433DATAPIN 2
#define TX433DATAPIN 4
// hardware interrupt connected to the pin
// with Arduino UNO interrupt-0 belongs to pin-2, interrupt-1 to pin-3
#define RX433INTERRUPT 0
// Set speed of serial in Arduino IDE to the following value
#define SERIALSPEED 115200
// Now make some suggestions about pulse lengths that may be detected
// minimum duration (microseconds) of the start pulse
#define MINSTARTPULSE 4500
// minimum duration (microseconds) of a short bit pulse
#define MINBITPULSE 450
// minimum duration (microseconds) of a HIGH pulse between valid bits
#define MINHITIME 50
// variance between pulses that should have the same duration
#define PULSEVARIANCE 250
// minimum count of data bit pulses following the start pulse
#define MINPULSECOUNT 20
// maximum count of data bit pulses following the start pulse
#define MAXPULSECOUNT 50
// buffer sizes for buffering pulses in the interrupt handler
#define PBSIZE 216
//----------------------TXstarten---------------------------
unsigned long tx_millis=0;
  lcd.begin ();
  lcd.clear ();
  Serial.println("Start!");
  lcd.setCursor(1,0);
  lcd.print("AndalinhoPearl");
  lcd.setCursor(1,1);
  lcd.print("warte auf PT-250");
  pinMode(RX433DATAPIN, INPUT);
  pinMode(TX433DATAPIN, OUTPUT);
  attachInterrupt(RX433INTERRUPT, rx433Handler, CHANGE);
  //----------------------tx sender
  vw_set_ptt_inverted(true); // Required for RF Link module
  vw_setup(2000);            // Bits per sec
  vw_set_tx_pin(TX433DATAPIN);
  pinMode(13, OUTPUT);       // Internal LED will blink on transmit
  tx_millis=millis();
volatile unsigned int pulsbuf[PBSIZE]; // ring buffer storing LOW pulse lengths
volatile unsigned int hibuf[PBSIZE]; // ring buffer storing HIGH pulse lengths
unsigned int validpulsbuf[MAXPULSECOUNT]; // linear buffer storing valid LOW pulses
unsigned int validhibuf[MAXPULSECOUNT];  // linear buffer storing valid HIGH pulses
volatile byte pbread,pbwrite;  // read and write index into ring buffer
unsigned long Sequenz, LastSequenz;
unsigned int CRC, LastCRC;
unsigned int SequenzCounter;
unsigned long LastSequenzMillis;
void rx433Handler()
  static long rx433LineUp, rx433LineDown;
  long LowVal, HighVal;
  int rx433State = digitalRead(RX433DATAPIN); // current pin state
  if (rx433State) // pin is now HIGH
    rx433LineUp=micros(); // line went HIGH after being LOW at this time
    LowVal=rx433LineUp - rx433LineDown; // calculate the LOW pulse time
    if (LowVal>MINBITPULSE)
    { // store pulse in ring buffer only if duration is longer than MINBITPULSE
      // To be able to store startpulses of more than Maxint duration, we dont't store the actual time,
     // but we store  MINSTARTPULSE+LowVal/10, be sure to calculate back showing the startpulse length!
      if (LowVal>MINSTARTPULSE) LowVal=MINSTARTPULSE+LowVal/10; // we will store this as unsigned int, so do range checking
      pulsbuf[pbwrite]=LowVal; // store the LOW pulse length
      pbwrite++;  // advance write pointer in ringbuffer
      if (pbwrite>=PBSIZE) pbwrite=0; // ring buffer is at its end
    rx433LineDown=micros(); // line went LOW after being HIGH
    HighVal=rx433LineDown - rx433LineUp; // calculate the HIGH pulse time
    if (HighVal>31999) HighVal=31999; // we will store this as unsigned int
    hibuf[pbwrite]=HighVal; // store the HIGH pulse length
boolean counting;
byte i,counter;
int startBitDurationL,startBitDurationH,shortBitDuration,longBitDuration;
String aStr = "";
int BinStrToInt(String aStr);
void showBuffer()
// this function will show the results on the serial monitor
// output will be shown if more bits than MINPULSECOUNT have been collected
  long sum;
  int avg;
  sum=0;
  if (counter>=MINPULSECOUNT)
  { // only show buffer contents if it has enough bits in it
    Serial.print("Start Bit L: "); Serial.print((startBitDurationL-MINSTARTPULSE)*10L);
    Serial.print("   H: ");Serial.println(startBitDurationH);
    Serial.print("Data Bits: ");Serial.println(counter);
    Serial.print("L: ");*/
    for (i=0;i<counter;i++)
      //Serial.print(validpulsbuf[i]);Serial.print(" ");
      sum+=validpulsbuf[i];
     avg = sum / counter; // calculate the average pulse length
    // then assume that 0-bits are shorter than avg, 1-bits are longer than avg
      if (validpulsbuf[i] < avg) {
        //        Serial.print('0');
        if (i > 1 && i < 34) {
          Sequenz <<= 1;                  // eine 0 von rechts rein
        else if (i >= 34) {
          CRC <<= 1;                  // eine 0 von rechts rein
      else {
        //        Serial.print('1');
          Sequenz <<= 1;
          Sequenz |= 1;               // eine 1 von rechts rein
        else if (i >= 34) {
          CRC <<= 1;
          CRC |= 1;               // eine 1 von rechts rein
  if (Sequenz != 0 ) {
    if (Sequenz == LastSequenz) {
      SequenzCounter++;
    else SequenzCounter = 0;
    LastSequenz = Sequenz;
    LastCRC = CRC;
    Sequenz = 0;
    CRC = 0;
    LastSequenzMillis = millis();
  counting = false;
  counter = 0;
  long lowtime, hitime;
  if (pbread!=pbwrite) // check for data in ring buffer
    lowtime=pulsbuf[pbread]; // read data from ring buffer
    hitime=hibuf[pbread];
    cli(); // Interrupts off while changing the read pointer for the ringbuffer
    pbread++;
    if (pbread>=PBSIZE) pbread=0;
    sei(); // Interrupts on again
    if (lowtime>MINSTARTPULSE) // we found a valid startbit!
      if (counting) showBuffer(); // new buffer starts while old is still counting, show it first
      startBitDurationL=lowtime;
      startBitDurationH=hitime;
      counting=true;     // then start collecting bits
      counter=0;         // no data bits yet
    else if (counting && (counter==0)) // we now see the first data bit
    { // this may be a 0-bit or a 1-bit, so make some assumption about max/min lengths of data bits that will follow
      shortBitDuration=lowtime/2;
      if (shortBitDuration<MINBITPULSE+PULSEVARIANCE)
        shortBitDuration=MINBITPULSE;
        shortBitDuration-=PULSEVARIANCE;
      longBitDuration=lowtime*2+PULSEVARIANCE;
      validpulsbuf[counter]=lowtime;
      validhibuf[counter]=hitime;
      counter++;
    else if (counting&&(lowtime>shortBitDuration)&&(lowtime<longBitDuration))
      counter++;
      if ((counter==MAXPULSECOUNT) || (hitime<MINHITIME))
        showBuffer();
    else // Low Pulse is too short
      counting=false;
      counter=0;
   if (millis() > LastSequenzMillis + 1000 && SequenzCounter > 3) {   // enought time since last conversion
    StoreMeas();
void StoreMeas() {
  // start conversion
  Serial.print(SequenzCounter);
  Serial.print(" ");
  Serial.print(LastSequenz, BIN);
  Serial.print(" ");
  Serial.print(LastCRC, BIN);
  SequenzCounter = 0;
  Serial.print("\t");
  Serial.print(millis()/1000);
  Serial.print("\tSensor ID: ");
  int SensorID = LastSequenz >> 24;
  Serial.print(SensorID);
  int Kanal = (LastSequenz >> 18) & 0b11;
  int Kanal_d = (Kanal + 1);
  Serial.print("\tKanal: ");
  Serial.print(Kanal_d, DEC);
  int Temp_i = (LastSequenz>>6) & 0b1111111111;
  Serial.print("\tTemp: ");
  Serial.print(Temp_i);
  lcd.clear();
  lcd.print("Temperatur ");
  lcd.print(Temp_i, DEC);
  lcd.setCursor(1,1),
  lcd.print("Kanal "),
  lcd.print(Kanal_d, DEC);
  vw_send((uint8_t *) &Kanal, sizeof(Kanal));
  vw_send((uint8_t *) &Temp_i, sizeof(Temp_i));
  vw_wait_tx();
  Serial.print("\tübertragen "); Serial.print(Temp_i );
  Serial.print("\tübertragen "); Serial.print(Kanal_d );
  delay(700);
hab mich jetzt für rc switch entschieden ist schneller als virtuel wire
#include <RCSwitch.h>
#include <Wire.h>
#define PBSIZE 216
RCSwitch mySwitch = RCSwitch();
  lcd.begin ();
  lcd.clear ();
  lcd.setCursor(1,0);
  lcd.setCursor(1,1);
  mySwitch.enableTransmit(4);
  tx_millis=millis();
void rx433Handler()
boolean counting;
byte i,counter;
String aStr = "";
void showBuffer()
  long sum;
  int avg;
  sum=0;
        else if (i >= 34) {
      else {
          Sequenz <<= 1;
        else if (i >= 34) {
          CRC <<= 1;
      SequenzCounter++;
    LastCRC = CRC;
    Sequenz = 0;
    CRC = 0;
  counting = false;
  counter = 0;
    pbread++;
      counter++;
      counter++;
        showBuffer();
      counting=false;
      counter=0;
    StoreMeas();
void StoreMeas() {
  // start conversion
  Serial.print(" ");
  Serial.print(" ");
  SequenzCounter = 0;
  Serial.print("\t");
  lcd.clear();
  lcd.setCursor(1,1),
  mySwitch.send(Temp_i, DEC);
und das bau ich in den Mega mit Ethernetshield ein
  mySwitch.enableReceive(0);  // Empfänger ist an Interrupt-Pin "0" - Das ist am UNO der Pin2,3 am Mega 2, 3, 18, 19, 20, 21
  if (mySwitch.available()) // Wenn ein Code Empfangen wird...
    int value_pearl = mySwitch.getReceivedValue(); // Empfangene Daten werden unter der Variable "value_pearl" gespeichert.
    if (value_pearl == 0) // Wenn die Empfangenen Daten "0" sind, wird "Unbekannter Code" angezeigt.
      Serial.println("Unbekannter Code");
    else // Wenn der Empfangene Code brauchbar ist, wird er hier an den Serial Monitor gesendet.
      Serial.print("\t");
      Serial.print("\tEmpfangen: ");
      Serial.print(value_pearl);
    mySwitch.resetAvailable(); // Hier wird der Empfänger "resettet"
