Port manipulation UNO: Issue
Hi all,
I am using an Arduino UNO WIFI Rev2 (Atmel Mega 4809) for my project to alter the output state of a pin via port manipulation. I have a multimeter connected to Pin 8, monitoring the state of the pin. After executing this code, as given below, I expected the voltage to toggle between 5 and 0 v every 1 s. Unfortunately, it was not happening! Something is wrong with my code, since it is working properly if I use the digital write command. Just a note: this code complied properly. Any help to fix it will be useful.
-Ac
   pinMode(8, OUTPUT);
// the loop function runs over and over again forever
  VPORTB.OUT = VPORTB.IN & B1111110;
  VPORTB.OUT = VPORTB.IN | B00000001;
Did it happen with the LED on the pin?
VPORT ?
Something new ?
Does the UNO WIFI use the UNO PORT arrangement ?
You don't need to read the input.
  VPORTB.OUT &= B11111110;
  VPORTB.OUT |= B00000001;
HTH
a7
Please be accurate; there is a difference between an Arduino Uno WiFi (which is 328P based) and an Arduino Uno WiFi Rev2 (which is 4809 based). Your code indicates the latter.
Assuming UNO WIFI Rev2, pinMode(8, OUTPUT); sets PE3 as output.
You’re toggling PB0. It’s not the same pin.
Thanks @stitech!
Updated code is attached for the rest of community who may face similar trouble.
@stitech
I found port maps for Atmega168 and Atmega8
I could not find maps for Atmega4809. Suggestions?
   pinMode(8, OUTPUT);
  VPORTE.OUT &= B11110111;
  VPORTE.OUT |= B00001000;
  delay(1000);                    // wait for a second
Try: https://ww1.microchip.com/downloads/aemDocuments/documents/MCU08/ProductDocuments/DataSheets/ATmega4808-09-DataSheet-DS40002173C.pdf
It doesn't contain a map, but it contains everything you need.
The schematic is your friend :wink: Relevant part
