HI i want to create a device that i can input a 3.5 audio jack select and control each eq frequency and change them up or down manualy then output the audio in real time to 3.5 jack with a graphic interface
Yes.
I use an app called Rocketplayer on my phone for an MP3 player, has equalizer built in as well. Maybe pick up a cheap phone and a big memory card (64GB) and use that instead? Nice display built right in then too.
no ideally i want to plug my mp3 player in to a device and then manually select each of the 10 or however many eq levels and change them manually is this possible with Arduino ?
I want to create a device where i plug my mp3 player in select which frequency i want to to change via a graphic interface then lower or rase the frequency in real time.
Basically a digital version of an EQ you get with some Hi-fis
having realised i can adjust a song EQ frequency with software to my personal taste i just don't want to be doing that with 1000s of tracks and am sorry but EQ presets just don't seam to cut it with me
You can probably do it with a [u]Raspberry Pi[/u], and you probably wouldn't have to build any hardware or write any software yourself. Or, you could write an EQ application yourself if you can do DSP programming.
Or, you could just buy a [u]little amplifier[/u] (or not so little amplifier) with built-in bass & treble controls, or you could buy a [u]graphic equalizer[/u] for less than it would cost to build one.
It's been done a million times, but I have no idea if it's been done on an Arduino Due or a Raspberry Pi.
ok thats great so where do i start?, how do i learn?
Audio & video manipulation falls under the category of [u]digital signal processing[/u] (DSP). As a general rule it takes a lot of processing power do do DSP in real time. (Some things like a like volume change are simple and don't require much processing.) Of course a PC or Mac can do DSP, or there are special-purpose DSP chips.
DSP is considered an advanced programming topic (and an advanced math topic) and if you were majoring in programming (Computer Science) at a university it would probably be a 4th year class. But, there is a good FREE online book called [u]The Scientist and Engineer's Guide toDigital Signal Processing, by By Steven W. Smith[/u]. (That book is not specific to any particular hardware or any particular programming language.)
Thanks Rob. I kept getting a missing token message, really irritating.
Musicmac, did you find an equalizer? I'm not seeing existing hardware solutions that aren't AC powered.
An equalizer is just a collection of bandpass filters, I'm sure you could make up 20 of them (10 per channel) with digitally controlled pots for adjusting the level and an Arduino to control the pots, with some kind of OLED/TFT/LCD screen to show you the selected levels. Could be a bit power hungry.
Utilizes 4760B dual-core processor for stellar audio performance
Dual micro SD ports - store up to 256 GB (not included)
Battery lasts 12 - 15 hours, recharges via USB
10-band graphic equalizer helps dial in the perfect sound
Headphone, line, and coaxial outputs
And run this app with 10-band equalizer, it's the one I use on my Samsung SIII phone
Free Equalizer
with 11 built-in presets
Beethoven listener? Try the classical preset. Bob Dylan more your style? Give the folk preset a listen. Prefer to customize? Not to worry, you can customize the EQ to your liking. Audiophile? Upgrade to Rocket Player Premium’s 10 band EQ. Save your custom EQs along with your 21 presets to specific songs.
The Due should do it well, I had 2 setup earlier this year... one read wav files off SD and output them to amp and to a speaker. The other sampled the DAC from the 1st and created 256 equalizer bands and displayed the data on a LCD screen without problems.
I'm guessing once you have the basics setup you can tweak it until the cows come home... or whatever the saying is.
I have a highly modified FFT routine that uses 32 bit fixed point somewhere off memory.
The original grabbed samples @ 44100 via the dac and added to an array... when 512 samples where fetched it did the FFT after copying the array to a work area. I was previously looking at making it do a little bit more work each cycle and spread the load out.
Must admit, frequency sweep with 256 bars looks cool :o
