I've been trying to grasp Arduino interrupts by reading the extraordinary good guide on Gammon Forum : Electronics : Microprocessors : Interrupts as well as trying to understand the Atmel datasheet for the ATmega 328P. Not sure I manged to fully digest every detail though...
I am currently using the twi bus so SDA and SCL lines are connected to pins A4 and A5. Now, I would like to enable a pin change interrupt on pin A2. Since A2 belongs to PORTC I need to enable the PORTC interrupt. I guess it would something like this
ISR (PCINT1_vect) {
++my_counter;
PCMSK0 |= bit (PCINT10); // want pin A2
PCICR |= bit (PCIE1); // enable pin change interrupts for A0 to A
Now my questions;
Because A4 and A5 also belongs to PORTC, will any twi bus activity on A4/A5 cause the interupt service intended for A2 to fire as well? Or will I break the twi-bus functionallity when I set PCICR to enable interrupts only on pin A2?
Thanks in advance!
I doubt it, but you could set up a quick test.
If you have enabled interrupts on those pins, it seems it detects them. But otherwise not.
Example test:
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
volatile bool interrupted;
ISR (PCINT1_vect)
// handle pin change interrupt for A0 to A5 here
interrupted = true;
} // end of PCINT1_vect
#include <Wire.h>
Serial.println ();
Serial.println ("I2C scanner. Scanning ...");
byte count = 0;
Wire.begin();
// pin change interrupt
PCMSK1 = bit (PCINT10); // want pin A2
PCIFR |= bit (PCIF1); // clear any outstanding interrupts
PCICR |= bit (PCIE1); // enable pin change interrupts for A0 to A5
Serial.begin (115200);
for (byte i = 8; i < 120; i++)
Wire.beginTransmission (i);
if (Wire.endTransmission () == 0)
Serial.print ("Found address: ");
Serial.print (i, DEC);
Serial.print (" (0x");
Serial.print (i, HEX);
Serial.println (")");
count++;
delay (1); // maybe unneeded?
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
} // end of setup
if (interrupted)
Serial.println ("Interrupted");
interrupted = false;
delay (200);
That exercises the I2C pins but since I only wanted an interrupt on A2, I did not see "Interrupted" printed.
But if you enable interrupts on those pins, you do see it:
PCMSK1 = bit (PCINT10) | bit (PCINT12) | bit (PCINT13); // want pin A2 / A4 / A5
Nick I find your result odd (can't see an error in your code) after all a pin on that port has changed, so the pin change int should fire. And I don't recall seeing any special rule on this in the data sheet.
What happens if you try this with SPI/Serial and pin change on those ports?
Mark
See the datasheet:
13.2.7 PCMSK1 – Pin Change Mask Register 1
Each PCINT[14:8]-bit selects whether pin change interrupt is enabled on the corresponding I/O pin.
You can mask out that only certain pins cause a pin-change interrupt. The entire group of pins uses one interrupt vector but they don't all have to cause the interrupt.
I don't know. You could try it.
So basically pin-change interrupts can be as fine-grained as external interrupts. You can choose to have only one pin cause an interrupt. However if the are all from the same "group" of pins only a single interrupt vector is called, and in that case (and that case alone) you need to decide inside the ISR which pin caused the interrupt.
Nice - and as you have already said very useful
Mark
@snoozerman:
To be sure, just assign, like this:
PCMSK1 = bit (PCINT10); // only want pin A2
Also, important!, it is PCMSK1 not PCMSK0. Read my page carefully where I list which masks apply to which pins.
D0 PCINT16 (PCMSK2 / PCIF2 / PCIE2)
D1 PCINT17 (PCMSK2 / PCIF2 / PCIE2)
D2 PCINT18 (PCMSK2 / PCIF2 / PCIE2)
D3 PCINT19 (PCMSK2 / PCIF2 / PCIE2)
D4 PCINT20 (PCMSK2 / PCIF2 / PCIE2)
D5 PCINT21 (PCMSK2 / PCIF2 / PCIE2)
D6 PCINT22 (PCMSK2 / PCIF2 / PCIE2)
D7 PCINT23 (PCMSK2 / PCIF2 / PCIE2)
D8 PCINT0 (PCMSK0 / PCIF0 / PCIE0)
D9 PCINT1 (PCMSK0 / PCIF0 / PCIE0)
D10 PCINT2 (PCMSK0 / PCIF0 / PCIE0)
D11 PCINT3 (PCMSK0 / PCIF0 / PCIE0)
D12 PCINT4 (PCMSK0 / PCIF0 / PCIE0)
D13 PCINT5 (PCMSK0 / PCIF0 / PCIE0)
A0 PCINT8 (PCMSK1 / PCIF1 / PCIE1)
A1 PCINT9 (PCMSK1 / PCIF1 / PCIE1)
A2 PCINT10 (PCMSK1 / PCIF1 / PCIE1)
A3 PCINT11 (PCMSK1 / PCIF1 / PCIE1)
A4 PCINT12 (PCMSK1 / PCIF1 / PCIE1)
A5 PCINT13 (PCMSK1 / PCIF1 / PCIE1)
Ahh lots of feedback here - thanks a lot! Thanks for the correction to PCMSK1 - that was a copy paste error by me using PCMSK0 :
So it appears it is possible to use the I2C and pin change interrupt without any them affecting eachother - that's great. But maybe it matter what library I use for the I2C bus. That is, if the lib relies on PORTC interupts or not I guess. Currently, I don't use <Wire.h> for some reason I don't fully remember anymore.
Good test. I should try something similar with the I2C lib I use.
Thanks!
I doubt another library uses interrupts when the hardware will do it for you. There is level detection going on in I2C which wouldn't be easy without hardware.
