Is this the normal Arduino behaviour that the serial monitor only works after a program has been uploaded?
It seems to me if I plug in the Portenta (I think this also happens with the Nano 33 IOT) using the regular IDE on Windows and I find the correct port and load the serial monitor nothing shows, however if I upload the program everything works fine.
On Ubuntu it is fairly easy to run to get the serial monitor up and running.
ls -l /dev/ttyACM*
screen /dev/ttyACM0
There is some confusing ctrl-a then :quit enter to get out of the program but I just close the terminal
By the way I am not a big fan of the following line of code, which shows up in most example programs as it blocks the running program and causes lots of frustration for my students, especially when running wifi or BLE and connecting the device to a generic power supply
while (!Serial) {}
Speaking of USB power supply connections, anyone else having a few issues with the Portenta when it is away from the computer USB connection?
Seems to run slightly differently I often get a flashing Green LED for no apparent reason. Especially if I use a USB hub connected to a wall wart and several devices powered by it.
