Refer to
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248217939
for the reasons as to why I am doing this.
* hserial.h
* Created on: Jul 25, 2009
* Author: Orlando Arias
* License: GPLv3
* Based off: HardwareSerial.h
#ifndef HSERIAL_H_
#define HSERIAL_H_
#include <inttypes.h>
#include "wiring.h"
#include "wiring_private.h"
#define RX_BUFFER_SIZE 128
typedef struct _ring_buffer {
unsigned char buffer[RX_BUFFER_SIZE];
int head;
int tail;
} ring_buffer;
typedef struct _hserial {
ring_buffer *rx_buffer;
volatile uint8_t *ubrrh;
volatile uint8_t *ubrrl;
volatile uint8_t *ucsra;
volatile uint8_t *ucsrb;
volatile uint8_t *udr;
uint8_t rxen;
uint8_t txen;
uint8_t rxcie;
uint8_t udre;
} hserial;
#if defined(__AVR_ATmega1280__)
hserial Serial[4];
#else
hserial Serial[1];
#endif
void hs_init(); // implemented
void hs_start(const int port, unsigned long baud); // implemented
uint8_t hs_available(const int port); // implemented
void hs_flush(const int port); // implemented
int hs_getChar(const int port); // implemented
void hs_writeChar(const int port, uint8_t c); // implemented
void hs_writeStr(const int port, const char str[]); // implemented
#endif /* HSERIAL_H_ */
* hserial.c
* License: GPLv3
* Based off: HardwareSerial.cpp
#include <stdio.h>
#include "wiring.h"
#include "hserial.h"
// function prototypes
void hs_parseStr(const int port, const char *str);
inline void store_char(unsigned char c, ring_buffer *rx_buffer);
// Initialize rx_buffer arrays accordingly.
ring_buffer rx_buffer[4] = { { { 0 }, 0, 0 },
{ { 0 }, 0, 0 }
{ { 0 }, 0, 0 }
{ { 0 }, 0, 0 } };
#else
ring_buffer rx_buffer[1] = { { { 0 }, 0, 0 } };
#endif
// serial macros
SIGNAL(SIG_USART0_RECV)
unsigned char c = UDR0;
store_char(c, &rx_buffer[0]);
SIGNAL(SIG_USART1_RECV)
unsigned char c = UDR1;
store_char(c, &rx_buffer[1]);
SIGNAL(SIG_USART2_RECV)
unsigned char c = UDR2;
store_char(c, &rx_buffer[2]);
SIGNAL(SIG_USART3_RECV)
unsigned char c = UDR3;
store_char(c, &rx_buffer[3]);
#else
#if defined(__AVR_ATmega8__)
SIGNAL(SIG_UART_RECV)
#else
SIGNAL(USART_RX_vect)
#endif
unsigned char c = UDR;
#else
#endif
#endif
// Initialize serial objects according to processor type.
void hs_init(){
Serial[0].rx_buffer = &rx_buffer[0];
Serial[0].ubrrh = &UBRRH;
Serial[0].ubrrl = &UBRRL;
Serial[0].ucsra = &UCSRA;
Serial[0].ucsrb = &UCSRB;
Serial[0].udr = &UDR;
Serial[0].rxen = RXEN;
Serial[0].txen = TXEN;
Serial[0].rxcie = RXCIE;
Serial[0].udre = UDRE;
#else
Serial[0].ubrrh = &UBRR0H;
Serial[0].ubrrl = &UBRR0L;
Serial[0].ucsra = &UCSR0A;
Serial[0].ucsrb = &UCSR0B;
Serial[0].udr = &UDR0;
Serial[0].rxen = RXEN0;
Serial[0].txen = TXEN0;
Serial[0].rxcie = RXCIE0;
Serial[0].udre = UDRE0;
#endif
Serial[1].rx_buffer = &rx_buffer[1];
Serial[1].ubrrh = &UBRR1H;
Serial[1].ubrrl = &UBRR1L;
Serial[1].ucsra = &UCSR1A;
Serial[1].ucsrb = &UCSR1B;
Serial[1].udr = &UDR1;
Serial[1].rxen = RXEN1;
Serial[1].txen = TXEN1;
Serial[1].rxcie = RXCIE1;
Serial[1].udre = UDRE1;
Serial[2].rx_buffer = &rx_buffer[2];
Serial[2].ubrrh = &UBRR2H;
Serial[2].ubrrl = &UBRR2L;
Serial[2].ucsra = &UCSR2A;
Serial[2].ucsrb = &UCSR2B;
Serial[2].udr = &UDR2;
Serial[2].rxen = RXEN2;
Serial[2].txen = TXEN2;
Serial[2].rxcie = RXCIE2;
Serial[2].udre = UDRE2;
Serial[3].rx_buffer = &rx_buffer[3];
Serial[3].ubrrh = &UBRR3H;
Serial[3].ubrrl = &UBRR3L;
Serial[3].ucsra = &UCSR3A;
Serial[3].ucsrb = &UCSR3B;
Serial[3].udr = &UDR3;
Serial[3].rxen = RXEN3;
Serial[3].txen = TXEN3;
Serial[3].rxcie = RXCIE3;
Serial[3].udre = UDRE3;
#endif
void hs_start(const int port, unsigned long baud){
*Serial[port].ubrrh = ((F_CPU / 16 + baud / 2) / baud - 1) >> 8;
*Serial[port].ubrrl = ((F_CPU / 16 + baud / 2) / baud - 1);
sbi(*Serial[port].ucsrb, Serial[port].rxen);
sbi(*Serial[port].ucsrb, Serial[port].txen);
sbi(*Serial[port].ucsrb, Serial[port].rxcie);
uint8_t hs_available(const int port){
return (RX_BUFFER_SIZE + Serial[port].rx_buffer->head -
Serial[port].rx_buffer->tail) % RX_BUFFER_SIZE;
int hs_getChar(const int port){
* If the head isn't ahead of the tail,
* we don't have any characters
if (Serial[port].rx_buffer->head == Serial[port].rx_buffer->tail) {
return -1;
unsigned char c =
Serial[port].rx_buffer->buffer[Serial[port].rx_buffer->tail];
Serial[port].rx_buffer->tail =
(Serial[port].rx_buffer->tail + 1) % RX_BUFFER_SIZE;
return c;
void hs_flush(const int port){
Serial[port].rx_buffer->tail;
void hs_writeChar(const int port, uint8_t c){
while (!((*Serial[port].ucsra) & (1 << Serial[port].udre)));
Serial[port].udr = &c;
void hs_writeStr(const int port, const char str[]){
hs_parseStr(port, str);
void hs_parseStr(const int port, const char *str){
while (*str)
hs_writeChar(port, *str++);
inline void store_char(unsigned char c, ring_buffer *rx_buffer){
int i = (rx_buffer->head + 1) % RX_BUFFER_SIZE;
// if we should be storing the received character into the location
// just before the tail (meaning that the head would advance to the
// current location of the tail), we're about to overflow the buffer
// and so we don't write the character or advance the head.
if (i != rx_buffer->tail) {
rx_buffer->buffer[rx_buffer->head] = c;
rx_buffer->head = i;
Test code:
* core.c
* Created on: Jul 26, 2009
* Author: tron
#include "WProgram.h"
#include "HD44780.h"
// declares a global LCD struct
LCD myLCD;
void setup(){
// set up pinout
myLCD.bitmode = BIT_MODE_4;
myLCD.enable_pin = 10;
myLCD.rs_pin = 12;
myLCD.rw_pin = 11;
for (int i=0;i<4;i++)
myLCD.datapin[i] = 5-i;
// initialize LCD
initLCD(&myLCD);
hs_init();
hs_start(0, 9600);
clearLCD(&myLCD);
writeStr(&myLCD, "Program Initialized.");
setCursor(&myLCD, 1,0);
writeStr(&myLCD, "Awaiting input...");
void loop(){
int incByte = 0;
if (hs_available(0) > 0){
clearLCD(&myLCD);
incByte = hs_getChar(0);
writeStr(&myLCD, "Received char: ");
writeChar(&myLCD, incByte);
I tried sending data away from the Arduino as well, reading the serial port using Minicom. Can't get that working either. No data seems to come out. I can read the output of the samples included with the Arduino IDE, but I can't send any data to the arduino.
Minicom settings:
A - Serial Device : /dev/ttyUSB0
B - Lockfile Location : /var/lock
C - Callin Program :
D - Callout Program :
E - Bps/Par/Bits : 9600 8N1
F - Hardware Flow Control : Yes
G - Software Flow Control : No
If I missed something, or something is wrong, please let me know. Thanks.
