Power: 72Watt
Output Voltage: 12V DC
Output Current: 6Amp
Supply Voltage:
120...373V DC
88...264V AC
Protection:
overload
short-circuit
voltage growth
Number of Outputs: 1
I measured 11.1 Volt in the output of the power supply (which is also the input to the DC2DC converter)
and I measured 4,65 Volt in the output of the output of the dc2dc converter. It should show 5 Volt. I use 1,5 mm^2 cables all inside the circuit and the connections, 3 pads for the conductors in the proto board and the supply network is 220Volt/50Hz. What could be wrong??
Have you ever measured other power supplies? Your numbers are within 5% so I would guess they are in spec (although, those parts do not provide specs).
Do not expect to spend $3 on ebay and get lab-grade instruments.
Can I fix the output voltage to be 5 Volt instead 4,65 Volts, which now as it is I can't use it. Any circuit to rise the voltage, and lose in current maybe?
I believe this does work (??), because it has adjustable output:
Module properties: non isolated buck module (BUCK)
XLSEMI XL4005E1
Input voltage: 5-32V
Continuous adjustable output voltage: 1-32V
Output current: 0-5A, recommended for use in 4.5A.
Output power: it is recommended to use in the 75W, more than 50W Please add heat sink.
Working temperature: -40~+85 degrees
Operating frequency: 180KHz
96%: the highest conversion efficiency (efficiency is related to the input, the output voltage, current, pressure difference)
Load adjustment rate: S (I) is less than or equal to 0.8%
Voltage regulation rate: S (U) is less than or equal to 0.8%
The resistors R1 and RBIAS set the output voltage.
They form a potential divider and the circuit regulates when the voltage on pin7 becomes 0.7V.
(Note that this is a 3.3V buck converter and so the values on your board are going to be different).
You should be able to trace the track from pin7 of IC U1 to identify which 2 resistors are involved.
(They won't be called R1 and RBIAS on your board, but I can't make them out from the photograph on the seller's website).
By changing the value of one or other of those 2 resistors you can adjust the output voltage. However you may not be able to get the voltage to be exactly 5V using standard resistor values.
Two items with a lower than expected voltage is suspicious. Test your DMM.
I have (had) a voltmeter that showed a lower voltage when the internal battery was almost flat.
Leo..
I changed dc2dc step down converter, I configured it to 5,1 Volt (and I measured with the multimeter to check it) , but when I measure the current I get 0 Amperes...and indeed the final device (the load) does not work..
alex5678:
My device needs 5 Volt to work, I thought 4,65 Volt was the issue for not working, but I realized that I have bigger problems, such as: no current!
What do you mean "no current"
Can you tell us what you project is and what it comprises of?
Ok. It is a circuit with sensors, CPU, IO and stuff like that. The load when stressed is 5A @ 5 Volts and the supply is 6A @ 12 Volt. Please also, see post #1. The project does heavy load processing. Thanx..
