Hi rndBit,
I am an applications engineer at Teknic and I ran across your post about the IPC-3/5 power supplies.
All NEMA 23/34 ClearPath motors can be powered from a DC power supply outputting 24 to 75Vdc, so you can use other 3rd party power supplies.
When choosing a power supply for your application, the size of the supply is going to be highly dependent on the exact application, the number of motors, and their sizes/windings. It’s almost impossible to predict exactly how much supply power you will need for a given application, but I can provide a general suggestion or two.
A higher voltage power supply will allow you to spin nearly any motor at higher speeds. Since power is torque * speed, a higher bus voltage will result in more mechanical output power. Teknic generally recommends using a 75V supply to get the most out of these motors. You can see the effect different voltages have of the torque speed curve for any motor right on Teknic’s website.
The amount of electrical power an application draws will also depend on both the torque and the speed of the motor(s) being used. A motor using a lot of torque at high speed will draw more power than a motor using torque but not moving, and a motor sitting still with no load will draw almost no power (unlike a stepper motor which always has holding current through the windings). This means that the power requirements of an application will vary as the system is in operation. With this in mind, it’s important to use a power supply with large peak reserves/capacitance, as opposed to using some switching supplies which are optimized to run with more or less constant loading.
DVDdoug - For the higher-power IPC-5 (350W continuous, 900W peak), you can always run at least one ClearPath motor of any size, in any application. With the lower-power, open-chassis IPC-3 (225W continuous, 900W peak), you can almost always run one ClearPath motor of most sizes, in most applications.
You can usually run two motors with an IPC-3, and in machines with smaller motors or when the motors are not moving at the same time, it’s possible to run four motors (or even more in certain cases). In the case of an IPC-5, I’ve seen instances of customers running 6 or more motors from one supply, although more commonly we see 2-4 motors instead.
Best regards,
Brendan
