Hi all,
I've gotten a ton of information from this forum, thank you. I know enough now to maybe be of help to others, so I joined.
And I have a question about supplying power to Arduino units. Briefly: is there any reason that the 5.2 to 5.6 VDC that USB chargers (AC-DC adapters outputting, typically, nominal 5.2 VDC) supply should be problematic to the Atmega controllers on these boards? I understand that chargers typically output >5 VDC whereas nominal 5V supplies do output 5.0 VDC.
I have searched and do understand that many people use chargers to power their Arduinos. I have done it and noticed no problems. I believe from specs and anecdotes that the voltage-range tolerance of controllers on these boards is ~3-5.5 VDC. My applications mean to be long-term datalogging. I want stuff to be real stable, this is why I'm asking.
What I'm interested in hearing is if someone has noteworthy experience (particularly, bad experience) with powering Arduinos at >5VDC through the units' power supply route that bypasses regulation (either to +5V pin or to USB in, which I do understand differ for the former's not having fuse or polarity protection). If not, that's swell too, and I'll be happy to know stuff ought to be fine.
Thanks!
