TrinsicWS:
cr0sh, Daanii, Brakk,
thanks for the advice! To be honest I am a bit afraid of having a psu on my bench
However, I think price/performance it may be the best. Off to look into one, cheers!
Why? Are you afraid of being shocked? Maybe you need to experience it...
When I was a kid, I got shocked more than a couple of times - only twice with a level that could have been fatal. On one of those occasions, I was reaching for the cutoff grounding switch on the top of a lawnmower engine on my gokart, and wasn't looking carefully (in my defence, I had just crashed my kart and was shutting down the engine), and grabbed the bare sparkplug connector (no rubber insulation) by mistake. The other time, I was messing with a cooler pump (110 VAC) to pump out some water from a kiddie pool my parents used to keep our dogs cool on our back porch in the summer (it was my job to clean the pool every weekend, and pumping the water out was waaaay quicker than bailing) - and the motor tipped over but kept running. Unthinking, I reached into the water to tip it back upright...
Also as a kid, I used to make "shocking" devices, by inverting various salvaged transformers to a step-up configuration. Adding a relay buzzer supplied the AC input current/signal needed (I don't recall if I ever added a capacitor across the input - probably not). Gather a bunch of kids (or a single kid), tell them to hold on, then "zot!". Very few could hold on for long. Got shocked several times by those kinds of things (I had a few geek friends that did such things as well, so we were all playing with this stuff).
As an adult, I'm more cautious around electricity - though there was one time I got shocked by an ignition coil on a fur-covered car at Burning Man...
What all this means is simply to be cautious, respect what you are doing, and if you are really concerned, keep one hand in your pocket, and probe/work with the other (and honestly, you should always try to avoid random probing on a live circuit, if at all possible - and if you must, probe with a single probe -only-). At the same time, you gotta live a little too, even if it means potentially getting shocked (and perhaps hard). Its a hazard, certainly - but being fearful does you no good, either.
