Hi all;
Is there a way to power an Arduino Uno with 3 AA batteries? The voltage would be under 5 volts but would an unregulated power supply burn out the Arduino if directly applied to the 5v pin?
Thanks!
Hi all;
Thanks!
No, that will be fine. The ATMega328 can run on less than 3 V, but other circuitry might not. Please delete your extra post.
How do you delete a post? I posted the extra one by accident - sorry.
Connect the 4.5V to the 5V/Gnd on the power header. Or to the USB power pins.
Battery is not considered an unregulated supply.
Duplicate deleted.
OP,
Another option is to buy a boost converter to convert your battery into 5V. I've used this one with 2 AA batteries. Current might be limited to 200mA though. I've used dozens of them so the quality is dependable.
The most you can use is probably 2 AA battery. 3 AA battery is likely too much, although I have not tested 3. If you don't need much power, use 1 AAA battery ![]()
