Hi friends! Long time listener, first time caller. I need some bearings before I dive face-first into my (first!) LED project.
I'm working out how I'm going to power my project from within my PC. My GPU is connected to the PSU with an 8-pin PCIe connector. There's another header spliced on the same lines (presumably for dual GPU setups). The output is 12V, which I understand is at the upper limit of what the Vin pin on my Arduino UNO can accept.
However, 12V is perfect! I took my LED strip from some stand lighting fixture that broke, and it accepts 12V. The driver IC is an SM16703P, whose data sheet also suggests a circuit for 12V. My plan is to power the Arduino and LED strip from the same line powering my GPU.
I drew up a schematic. You'll see the PSU-GPU power rail, a simplified LED strip circuit (without resistors/capacitors for ease-of-reading), and my precious thinking box.
Ultimately, as fun as it sounds, I don't want to destroy any equipment. Has anyone attempted a similar power setup? Are there potential current draw concerns? Should I put a diode between the power supply and the LEDs? Am I crazy for powering this setup off my own PSU?! I'd love to get some insights.
