Powering the Arduino Nano 33 IoT with 3.7V LiPo battery
I’m currently working on a wearable IoT device on the Arduino Nano 33 IoT that utilizes the built-in IMU sensor (LSM6DS3) and the Wi-Fi NINA module. Since it’s a wearable I’m looking for an external battery that can power it instead of using my computer or plugging it into a wall source. I’m considering using a 3.7 LiPo battery to power up my device but the operating voltage is 3.3V, while Vin only accepts voltage from 5V - 21V. So here are the options I weighed in:
  1. Connect 3.7V LiPo battery to Vin - may not be sufficient as the minimum voltage for Vin is 5V. So I should use a step up voltage converter to boost it to 5V.
  2. Connect two 3.7V LiPo batteries in series to Vin, so the 7.4V will be stepped down by the Arduino’s voltage regulator
  3. Connect 3.7V LiPo battery to 3V3 along with step down converter - although I try to avoid this option because I’ve read supplying voltage directly to 3V3 may damage the Arduino
Can someone let me know which one would be the most viable option? Also, besides LiPo batteries, I’ve considered using alkaline batteries as well but I read elsewhere that they can't really power projects for long-term periods. If there are other feasible or safer alternatives to LiPo batteries do let me know. Sorry I’m new to electronics so my knowledge on this kind of stuff isn’t be that deep lol
Number 2 is the simplest solution and does not require any additional hardware.
The nano 33 has a switching buck converter on it so the efficiency should be fairly high.
Either option 2. or LiFePo (3.2V) battery directly to 3.3V. Or use different board, something that has battery management built in.
Forgot to mention - do I need to connect a protection circuit (such as TP4056) to the Arduino project? Or is it only for charging purposes?
The TP4056 module is only for one battery. It is mostly used for charging but some do have extra protection on the module
Most Li-ion batteries already have built-in protection.
When I bought the LiPo batteries it says that built-in protection is not included :sweat_smile: so how do I overcome this if I use 2 batteries in series?
You buy BMS for 2S battery.
