Precision calculation problems in arduino DUE
I have an arduino DUE to make a program that requires high-precision calculations, but the results are not as expected by comparing the results that I calculated using Excel which has tested the results.
I include screenshots and sketches to make it easier for you to understand.
I hope someone can help with my project, thanks for those who want to think about this.
 #include <math.h>
 int l=-6,b=109,tgl=13,bln=6,thn=2020,j=1,mnt=0,dtk=0,zw=(b/15);
      int M,Y,A,B;
      double Tahun = thn+(bln-1)/12+tgl/365;
      double delta;
      double bujurRataM;
      double anomaliRataM;
      double koreksiM;
      double bujurEkliptikaM;
      double omegaM;
      double epsilonZero;
      double deltaEpsilon;
      double epsilon;
      double JDUT;
      double TuJD;
      double GST_UT;
      double GST_L;
      double LST;
      double bujurNampakM;
      double alphaM;
      double deltaM;
      double hourAngle;
      double azimuthMselatan;
      double azimuthM;
      double altitudM;
      Serial.begin (115200);
      if (bln<3)
      M = bln+1;
      M = bln;
    if (bln<3)
      Y = thn-1;
      Y = thn;
    A=(Y/100);
    B = (2+int (A/4)-A);
    if (Tahun>2005)
      if(Tahun<=2050)
        delta = 62.92 + 0.32217*(Tahun-2000) + 0.005589*(Tahun-2000)*(Tahun-2000);
        delta = 0;
      delta = 0;
  double JDU = 1720994.5+int32_t(365.25*Y)+int32_t(30.60001*(M+1))+B+tgl+(j+mnt/60+dtk/3600)/24 - zw/24;
    double JDE = JDU+(delta/86400);
      double T = (JDE-2451545)/36525;
    JDUT = 1720994.5+int32_t(365.25*Y)+int32_t(30.60001*(M+1))+B+j;
      TuJD = (JDUT-2451545)/36525;
        GST_UT = fmod(6.6973745583+2400.0513369072*TuJD+0.0000258622*TuJD*TuJD,24);
          GST_L = fmod(GST_UT+(j+mnt/60+dtk/3600)*1.00273790935,24);
            LST = fmod(GST_L+b/15,24);
    //Posisi Matahari
    bujurRataM = fmod(280.46646+36000.76983*T+0.0003032*T*T,360);
      anomaliRataM = fmod(357.5291092 + 35999.0502909*T - 0.0001536*T*T + T*T*T/24490000, 360);
        koreksiM = (1.914602 - 0.004817*bujurRataM - 0.000014*bujurRataM*bujurRataM)*sin(radians(anomaliRataM)) + (0.019993 - 0.000101*bujurRataM)*sin(2*radians(anomaliRataM)) + 0.000289*sin(3*radians(anomaliRataM));
          bujurEkliptikaM = bujurRataM + koreksiM;
    omegaM = fmod(125.04-1934.136*T,360);
    epsilonZero =  23 + 26/60 + 21.448/3600 - 46.815*T/3600 - 0.00059*T*T/3600 + 0.001813*T*T*T/3600;
      deltaEpsilon = 0.00256*cos(radians(omegaM));
        epsilon = epsilonZero + deltaEpsilon;
    bujurNampakM = bujurEkliptikaM-0.00569-0.00478*sin(radians(omegaM));
      alphaM = fmod(degrees(atan2(cos(radians(bujurNampakM)),cos(radians(epsilon))*sin(radians(bujurNampakM)))),360);
    deltaM = -degrees(asin(sin(radians(epsilon))*sin(radians(bujurNampakM))));
        hourAngle = fmod(LST-alphaM,24)*15;
          azimuthMselatan = atan2(cos(radians(hourAngle))*sin(radians(l))-tan(radians(deltaM))*cos(radians(l)),sin(radians(hourAngle)));
            azimuthM = fmod(radians(azimuthMselatan)+180,360);
          altitudM = degrees(asin(sin(radians(l))*sin(radians(deltaM))+cos(radians(l))*cos(radians(deltaM))*cos(radians(hourAngle))));
          Serial.print("Y = " );
        Serial.println(Y);
        Serial.print("A = " );
        Serial.println(A);
        Serial.print("B = " );
        Serial.println(B);
        Serial.print("delta = " );
        Serial.println(delta);
        Serial.print("JDU = " );
        Serial.println(JDU);
        Serial.print("JDE = " );
        Serial.println(JDE);
        Serial.print("T = " );
        Serial.println(T);
        Serial.print("bujurRataM = " );
        Serial.println(bujurRataM);
        Serial.print("anomaliRataM = " );
        Serial.println(anomaliRataM);
        Serial.print("koreksiM = " );
        Serial.println(koreksiM);
        Serial.print("bujurEkliptikaM = " );
        Serial.println(bujurEkliptikaM);
        Serial.print("omegaM = " );
        Serial.println(omegaM);
        Serial.print("epsilonZero = " );
        Serial.println(epsilonZero);
        Serial.print("deltaEpsilon = " );
        Serial.println(deltaEpsilon);
        Serial.print("epsilon = " );
        Serial.println(epsilon);
        Serial.print("JDUT = " );
        Serial.println(JDUT);
        Serial.print("TuJD = " );
        Serial.println(TuJD);
        Serial.print("GST_UT = " );
        Serial.println(GST_UT);
        Serial.print("GST_L = " );
        Serial.println(GST_L);
        Serial.print("LST = " );
        Serial.println(LST);
        Serial.print("bujurNampakM = " );
        Serial.println(bujurNampakM);
        Serial.print("alphaM = " );
        Serial.println(alphaM);
        Serial.print("deltaM = " );
        Serial.println(deltaM);
        Serial.print("hourAngle = " );
        Serial.println(hourAngle);
        Serial.print("azimuthMselatan = " );
        Serial.println(azimuthMselatan);
        Serial.print("azimuthM = " );
        Serial.println(azimuthM);
        Serial.print("altitudM = " );
        Serial.println(altitudM);
Try printing the value of 'Tahun' and see if it's what you expect.
Is this just a matter of printing more decimal places?
DUE doubles are 8 bytes, so shoukd be accurate if you’ve transcribed the formulae correctly. Try
        Serial.println(alphaM, 6);
HTH
a7
Please could
you get
used to
using the auto-
format
tool before
posting your
code?
Can you post the excel formula for the Julian date? There are parts of that equation that need to be done as integer math (dropping the fractional part). The excel value ending in something other than 0.50 looks suspicious.
this is not only a matter of printing, but about the precision of the stored value results which will then be used for the next calculation.
The formula I use in Excel is of course the same as the one in sketch
Only if you wrote the Excel code correctly, and you gave us no reason to believe that you did.
sorry, I don't understand what you mean
Your code wanders over the page like it is drunk, and makes it hard to read.
Using the IDE's auto-format tool would help fix that.
Still looks wrong, Julian date should end in 0.50 because the day starts at noon instead of midnight.
Delta also looks incorrect, using a calculator gives a result of 71.599, which is what I get from the sketch you previously posted a few weeks ago with the same formula you are currently using (which originally comes from a NASA paper, I believe).
< edit > Also, it is very easy to calculate the Julian date from the unit timestamp, much simpler than doing the normal calculation, and usable as long as the year is after 1970.
It looks like Arduino doubles on DUE are according to the
IEEE 754 binary64 standard
Excel also adheres to IEEE 754, but I do not know what number of bytes are used.
I think you can expect to get similar or at least acceptable calculations.
TBH squinting at your screen shotz is without my capability. It would be easier to see what you are complaining about if you posted text we can all cut and paste and work with in our habitual ways.
a7
does that mean I need to crop the screenshot to make it look clearer?
can you give me the julian day calculation you mean?
OMG, it's not that difficult!!!
The only screenshots are the spreadsheet and the results, but I'm talking about your Arduino sketch.
[code]
int l = -6, b = 109, tgl = 13, bln = 6, thn = 2020, j = 1, mnt = 0, dtk = 0, zw = (b / 15);
int M, Y, A, B;
double Tahun = thn + (bln - 1) / 12 + tgl / 365;
double delta;
double bujurRataM;
double koreksiM;
double omegaM;
double epsilonZero;
double epsilon;
double JDUT;
double TuJD;
double GST_UT;
double GST_L;
double LST;
double alphaM;
double deltaM;
double hourAngle;
double azimuthM;
double altitudM;
  if (bln < 3)
    M = bln + 1;
    M = bln;
  if (bln < 3)
    Y = thn - 1;
    Y = thn;
  A = (Y / 100);
  B = (2 + int (A / 4) - A);
  if (Tahun > 2005)
    if (Tahun <= 2050)
      delta = 62.92 + 0.32217 * (Tahun - 2000) + 0.005589 * (Tahun - 2000) * (Tahun - 2000);
      delta = 0;
    delta = 0;
  double JDU = 1720994.5 + int32_t(365.25 * Y) + int32_t(30.60001 * (M + 1)) + B + tgl + (j + mnt / 60 + dtk / 3600) / 24 - zw / 24;
  double JDE = JDU + (delta / 86400);
  double T = (JDE - 2451545) / 36525;
  JDUT = 1720994.5 + int32_t(365.25 * Y) + int32_t(30.60001 * (M + 1)) + B + j;
  TuJD = (JDUT - 2451545) / 36525;
  GST_UT = fmod(6.6973745583 + 2400.0513369072 * TuJD + 0.0000258622 * TuJD * TuJD, 24);
  GST_L = fmod(GST_UT + (j + mnt / 60 + dtk / 3600) * 1.00273790935, 24);
  LST = fmod(GST_L + b / 15, 24);
  //Posisi Matahari
  bujurRataM = fmod(280.46646 + 36000.76983 * T + 0.0003032 * T * T, 360);
  anomaliRataM = fmod(357.5291092 + 35999.0502909 * T - 0.0001536 * T * T + T * T * T / 24490000, 360);
  koreksiM = (1.914602 - 0.004817 * bujurRataM - 0.000014 * bujurRataM * bujurRataM) * sin(radians(anomaliRataM)) + (0.019993 - 0.000101 * bujurRataM) * sin(2 * radians(anomaliRataM)) + 0.000289 * sin(3 * radians(anomaliRataM));
  omegaM = fmod(125.04 - 1934.136 * T, 360);
  epsilonZero =  23 + 26 / 60 + 21.448 / 3600 - 46.815 * T / 3600 - 0.00059 * T * T / 3600 + 0.001813 * T * T * T / 3600;
  deltaEpsilon = 0.00256 * cos(radians(omegaM));
  bujurNampakM = bujurEkliptikaM - 0.00569 - 0.00478 * sin(radians(omegaM));
  alphaM = fmod(degrees(atan2(cos(radians(bujurNampakM)), cos(radians(epsilon)) * sin(radians(bujurNampakM)))), 360);
  deltaM = -degrees(asin(sin(radians(epsilon)) * sin(radians(bujurNampakM))));
  hourAngle = fmod(LST - alphaM, 24) * 15;
  azimuthMselatan = atan2(cos(radians(hourAngle)) * sin(radians(l)) - tan(radians(deltaM)) * cos(radians(l)), sin(radians(hourAngle)));
  azimuthM = fmod(radians(azimuthMselatan) + 180, 360);
  altitudM = degrees(asin(sin(radians(l)) * sin(radians(deltaM)) + cos(radians(l)) * cos(radians(deltaM)) * cos(radians(hourAngle))));
  Serial.print(Tahun);
  Serial.println(Y);
  Serial.println(A);
  Serial.println(B);
  Serial.println(T);
[/code]
These are all integers.
See reply #2
I give advise once. If it's ignored, I don't repeat it.
oke, then
