Hello! I'm trying to have the Arduino buzzer play a different tone depending on if 1 of three buttons are pressed. I'm having trouble with the loop as currently only the 1st button plays a tone when pressed while buttons 2 and 3 do not. I know the wiring is correct as individually the buttons work, so I think it's something with my code!:
const int button = 9; //buzzer to arduino pin 9
const int button2 = 10;
const int button3 = 11;
void setup(){
pinMode(button, OUTPUT); // Set buzzer - pin 9 as an output
pinMode(button2, OUTPUT);
pinMode(button3, OUTPUT);
void loop(){
int buttonstate = digitalRead(button);
int button2state = digitalRead(button2);
int button3state = digitalRead(button3);
if (buttonstate == LOW) { //if button 1 is pressed, play a tone at 1000HZ
Serial.println("Button 1 is being pressed");
tone(button, 1000);
if (buttonstate == HIGH && button2state == LOW && button3state == HIGH) { // if button 2 is pressed and button 1 and 3 aren't play a tone at 500HZ
Serial.println("Button 2 is being pressed");
tone(button2, 500);
if (buttonstate == HIGH && button2state == HIGH && button3state == LOW) { // if button 3 is pressed and button 1 and 2 aren't play a tone at 250HZ
Serial.println("Button 3 is being pressed");
tone(button3, 250);
else { //No sound is played if a button isn't pressed
noTone(button);
noTone(button2);
noTone(button3);
