Hello, there !
In one of the my project i am trying to print 3-digit (+Ve and -Ve) hard code decimal value on seven segment display. I am able to display digit 0 to 8 for all 3 digit but when i pass value "9" like random value "889" it shows only activated "G-segment" only for number 9 and 88 is showing correct in both +Ve and -Ve value. The code written for digit 9 is also ok but unable to find why it is like.
Currently i have 8-digit Seven segment display form there i am using 3 digit of it.
References :
1] abs()
Source code :
#include <LiquidCrystal.h>
// segment pins definitions
#define SegA 0
#define SegB 1
#define SegC 2
#define SegD 3
#define SegE 4
#define SegF 5
#define SegG 6
#define SegDP 7
#define digit_0 8
#define digit_1 10
#define digit_2 12
#define digit_3 14
#define digit_4 16
#define digit_5 18
#define digit_6 22
#define digit_7 24
uint8_t current_digit;
int temp;
LiquidCrystal lcd (38,37,36,35,34,33);
lcd.begin (16,4);
pinMode(SegA, OUTPUT);
pinMode(SegB, OUTPUT);
pinMode(SegC, OUTPUT);
pinMode(SegD, OUTPUT);
pinMode(SegE, OUTPUT);
pinMode(SegF, OUTPUT);
pinMode(SegG, OUTPUT);
pinMode(SegDP, OUTPUT);
pinMode(digit_0, OUTPUT);
pinMode(digit_1, OUTPUT);
pinMode(digit_2, OUTPUT);
pinMode(digit_3, OUTPUT);
pinMode(digit_4, OUTPUT);
pinMode(digit_5, OUTPUT);
pinMode(digit_6, OUTPUT);
pinMode(digit_7, OUTPUT);
digitalWrite(digit_0,LOW);
digitalWrite(digit_1,LOW);
digitalWrite(digit_2,LOW);
digitalWrite(digit_3,LOW);
digitalWrite(digit_4,LOW);
digitalWrite(digit_5,LOW);
digitalWrite(digit_6,LOW);
digitalWrite(digit_7,LOW);
// Timer1 module overflow interrupt configuration
TCCR1A = 0;
TCCR1B = 1; // enable Timer1 with prescaler = 1 ( 16 ticks each 1 µs)
TCNT1 = 0; // set Timer1 preload value to 0 (reset)
TIMSK1 = 1; // enable Timer1 overflow interrupt
ISR(TIMER1_OVF_vect) // Timer1 interrupt service routine (ISR)
digitalWrite(SegDP,HIGH);
int abs_temp = abs(temp); // abs: absolute value
switch (current_digit)
case 1:
if(temp < 0)
disp(10); // print minus sign (-)
digitalWrite(digit_6, HIGH);
digitalWrite(digit_6, LOW);
case 2:
disp(abs_temp / 100);
digitalWrite(digit_5, HIGH);
case 3:
disp( (abs_temp / 10) % 10);
digitalWrite(digit_4, HIGH);
case 4:
disp(abs_temp % 10);
digitalWrite(digit_3, HIGH);
digitalWrite(SegDP, LOW); // ON
current_digit = (current_digit % 4) + 1;
temp = -878; //-878
lcd.setCursor(0,0);
lcd.print(temp);
delay(100);
void disp(byte number)
switch (number)
case 0:
digitalWrite(SegA, HIGH);
digitalWrite(SegB, HIGH);
digitalWrite(SegC, HIGH);
digitalWrite(SegD, HIGH);
digitalWrite(SegE, HIGH);
digitalWrite(SegF, HIGH);
digitalWrite(SegG, LOW);
case 1:
digitalWrite(SegA, LOW);
digitalWrite(SegD, LOW);
digitalWrite(SegE, LOW);
digitalWrite(SegF, LOW);
case 2:
digitalWrite(SegC, LOW);
digitalWrite(SegG, HIGH);
case 3:
case 4:
case 5:
digitalWrite(SegB, LOW);
case 6:
case 7:
case 8:
case 9:
case 10: // print -
