Hello, I am a bit new to using Arduino hardware and IDE software (2.2.1). I am a not a programming expert but have enough coding knowledge to get things working mostly. I would like a little guidance to a project of mine using an UNO board and a MP3 player. I have uploaded the hardware breadboard diagram and below is the code I am using to run the mp3 paler. The player works fine functionally with the code I have loaded to the UNO board. But, I am needing a little guidance to be able to print a couple of variable values (volume level and song name) as the player is running and also how to send a CMD code from the serial monitor interface to the connected UNO board such as the command to change the volume level to a new value. Here is the code that I am using. I am not the originator of the code below. But, it works as described in the uploaded hardware diagram file. The MP3 player I am using is the DFROBOT DFPlayer MP3 Mini. Where and what code is needed to see the current volume level and song file name in the serial monitor window? And how do I send a command from the serial monitor window to change the current volume level to a new level? This guidance will help me learn how this is done in future coding I plan on doing. Thank You, Joe
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
# define ACTIVATED LOW
int buttonNext = 2;
int buttonPause = 3;
int buttonPrevious = 4;
int volumeUP = 5;
int volumeDOWN = 6;
int volume = 15;
boolean isPlaying = false;
void setup () {
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause,HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext,HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious,HIGH);
pinMode(volumeUP, INPUT);
pinMode(volumeDOWN, INPUT);
digitalWrite(volumeUP, HIGH);
digitalWrite(volumeDOWN, HIGH);
mySerial.begin (9600);
playFirst();
isPlaying = true;
void loop () {
if (digitalRead(buttonPause) == ACTIVATED)
if(isPlaying)
pause();
isPlaying = false;
}else
isPlaying = true;
play();
if (digitalRead(buttonNext) == ACTIVATED)
if(isPlaying)
playNext();
if (digitalRead(buttonPrevious) == ACTIVATED)
if(isPlaying)
playPrevious();
if(digitalRead(volumeUP) == ACTIVATED)
volumeINC();
if(digitalRead(volumeDOWN) == ACTIVATED)
volumeDEC();
void playFirst()
execute_CMD(0x3F, 0, 0);
execute_CMD(0x06, 0, volume);
execute_CMD(0x11,0,1);
void pause()
execute_CMD(0x0E,0,0);
void play()
execute_CMD(0x0D,0,1);
void playNext()
execute_CMD(0x01,0,1);
void playPrevious()
execute_CMD(0x02,0,1);
void volumeINC()
volume = volume+1;
if(volume==31)
volume=30;
void volumeDEC()
volume = volume-1;
if(volume==-1)
volume=0;
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
// Calculate the checksum (2 bytes)
word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge,
Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte};
//Send the command line to the module
for (byte k=0; k<10; k++)
mySerial.write( Command_line[k]);
