Hi ! I made an infinite printer Imgur: The magic of the Internet
I used the code from github in GCodeParser’s folder. I had to change some code lines. GRemoteFull is a program to send the Gcode to the aruino.
At the beginning the pen goes to 0. It had work before, but I had to change something and it doesn’t work anymore. Here is the part where then pen goes to 0 :
//init our points.
current_units.x = 0.0;
current_units.y = 0.0;
current_units.z = 0.0;
target_units.x = 0.0;
target_units.y = 0.0;
target_units.z = 0.0;
pinMode(X_STEP_PIN, OUTPUT);
pinMode(X_DIR_PIN, OUTPUT);
pinMode(X_ENABLE_PIN, OUTPUT);
pinMode(X_MIN_PIN, INPUT_PULLUP);
pinMode(X_MAX_PIN, INPUT_PULLUP);
pinMode(Y_STEP_PIN, OUTPUT);
pinMode(Y_DIR_PIN, OUTPUT);
pinMode(Y_ENABLE_PIN, OUTPUT);
//pinMode(Y_MIN_PIN, INPUT_PULLUP);
//pinMode(Y_MAX_PIN, INPUT_PULLUP);
pinMode(Z_STEP_PIN, OUTPUT);
pinMode(Z_DIR_PIN, OUTPUT);
pinMode(Z_ENABLE_PIN, OUTPUT);
//pinMode(Z_MIN_PIN, INPUT_PULLUP);
//pinMode(Z_MAX_PIN, INPUT_PULLUP);
//figure our stuff.
calculate_deltasbis();
goto_machine_zero();
void goto_machine_zero()
Serial.println("init");
move_to_max(X_MIN_PIN, X_STEP_PIN, X_DIR_PIN, 0);
// move_to_max(Y_MIN_PIN, Y_STEP_PIN, Y_DIR_PIN, 0);
Serial.println("ok");
void move_to_max(int limiter_pin, int stepper_pin, int stepper_dir_pin,int dir)
/* Moves to the maximum possible position
if(limiter_pin == 11 || limiter_pin == 12){
while(can_step(limiter_pin, limiter_pin, 0, 1, dir)){
do_step(stepper_pin, stepper_dir_pin, 0);
Serial.print("tapes");
delay(1);
// slowly back unitl pin is released
while(!can_step(limiter_pin, limiter_pin, 0, 1, dir)){
do_step(stepper_pin, stepper_dir_pin, 1);
Serial.print("recule");
delay(100);
else {
Serial.print("bouges");
void dda_move(long micro_delay)
//enable our steppers
digitalWrite(X_ENABLE_PIN, HIGH);
digitalWrite(Y_ENABLE_PIN, HIGH);
digitalWrite(Z_ENABLE_PIN, HIGH);
//figure out our deltas
max_delta = max(delta_steps.x, delta_steps.y);
max_delta = max(delta_steps.z, max_delta);
//init stuff.
long x_counter = -max_delta/2;
long y_counter = -max_delta/2;
long z_counter = -max_delta/2;
//our step flags
bool x_can_step = 0;
bool y_can_step = 0;
bool z_can_step = 0;
if (micro_delay >= 16383)
milli_delay = micro_delay / 1000;
milli_delay = 0;
//do our DDA line!
do
x_can_step = can_step(X_MIN_PIN, X_MAX_PIN, current_steps.x, target_steps.x, x_direction);
y_can_step = can_step(Y_MIN_PIN, Y_MAX_PIN, current_steps.y, target_steps.y, y_direction);
z_can_step = can_step(Z_MIN_PIN, Z_MAX_PIN, current_steps.z, target_steps.z, z_direction);
if (x_can_step)
x_counter += delta_steps.x;
if (x_counter > 0)
do_step(X_STEP_PIN, X_DIR_PIN, x_direction);
x_counter -= max_delta;
if (x_direction)
current_steps.x++;
current_steps.x--;
if (y_can_step)
y_counter += delta_steps.y;
if (y_counter > 0)
do_step(Y_STEP_PIN, Y_DIR_PIN, y_direction);
y_counter -= max_delta;
if (y_direction)
current_steps.y++;
current_steps.y--;
if (z_can_step)
z_counter += delta_steps.z;
if (z_counter > 0)
if(Z_ENABLE_SERVO==0){
do_step(Z_STEP_PIN, Z_DIR_PIN, z_direction);
z_counter -= max_delta;
if (z_direction)
current_steps.z++;
current_steps.z--;
//wait for next step.
if (milli_delay > 0)
delay(milli_delay);
delayMicroseconds(micro_delay);
while (x_can_step || y_can_step || z_can_step);
//set our points to be the same
current_units.x = target_units.x;
current_units.y = target_units.y;
current_units.z = target_units.z;
calculate_deltas();
bool can_step(byte min_pin, byte max_pin, long current, long target, byte direction)
//stop us if we're on target
if (target == current)
return false;
//stop us if we're at home and still going
else if (read_switch(min_pin) && !direction)
return false;
//stop us if we're at max and still going
else if (read_switch(max_pin) && direction)
return false;
//default to being able to step
return true;
void do_step(byte pinA, byte pinB, byte dir)
switch (dir << 2 | digitalRead(pinA) << 1 | digitalRead(pinB)) {
case 0: /* 0 00 -> 10 */
case 5: /* 1 01 -> 11 */
digitalWrite(pinA, HIGH);
case 1: /* 0 01 -> 00 */
case 7: /* 1 11 -> 10 */
digitalWrite(pinB, LOW);
case 2: /* 0 10 -> 11 */
case 4: /* 1 00 -> 01 */
digitalWrite(pinB, HIGH);
case 3: /* 0 11 -> 01 */
case 6: /* 1 10 -> 00 */
digitalWrite(pinA, LOW);
delayMicroseconds(5);
bool read_switch(byte pin)
//dual read as crude debounce
if ( SENSORS_INVERTING )
return !digitalRead(pin) && !digitalRead(pin);
return digitalRead(pin) && digitalRead(pin);
long to_steps(float steps_per_unit, float units)
return steps_per_unit * units;
This is the electronic setting : Imgur: The magic of the Internet
The pushbutton represent my limit sensor.
I don’t know if this is the correct way to make a post, I’m a beginner in Arduino’s coding and it’s my first post on a forum.
Don’t hesitate if you need more informations
Thank you all
