After measuring the frequency I get a 3 Byte variable (unsigned long freq) an I want to printed via serial monitor. But only the lower 16 bits are printed. I guess the binary to decimal routine uses only 16 bit even when the variable is declared long. How can I manage to get all 24 bits converted and printed?
You don't tell us which board, so I assume an Uno (or other 8-bit ATmega).
There a long is 4 bytes, not three. And the print routine is just fine in printing that, no problem
So the error most be in your, not posted, code. And/or your understanding of 3 byte being a long. ![]()
Sounds like you try to store your 32-bit long in a 16-bit int.
The associated libraries take some space but sprintf() makes formatting trivial:
char
szStr[20];
unsigned long
ulTest;
Serial.begin( 9600 );
ulTest = 0x5A0F;
sprintf( szStr, "%04X\t%ld", ulTest, ulTest );
Serial.println( szStr );
}//setup
}//loop
I know it's been a while, but people finding this code will be disappointed. The code supplied (specifically the sprintf( szStr, "%04X\t%ld", ulTest, ulTest ); line) fails on three counts:
- It only prints 4 hex digits rather than eight
- The hex formatting assumes an int rather than any sort of long
- The number itself assumes a signed long rather than unsigned long
This can be fixed by replacing the sprintf line with
sprintf( szStr, "%08lX\t%lu", ulTest, ulTest );
