Printing Hex into Serial Port
Hello! Can someone please help me identify where I am going wrong in this code. I am trying to print out the hexidecimal value exactly as it is shown.
char msgString[128];
  Serial.println("<Arduino is ready>");
  uint64_t receivedMsg = 0x1000000100000000;
  sprintf(msgString, "Incoming message: 0x%.16llX",receivedMsg);
  Serial.println(msgString);
looks correct for me:
Incoming message: 0x1000000100000000
what do you expect instead?
What do you see in the Serial Monitor after the execution of: Serial.println(msgString)?
That's exactly what I expect, however I only see
it works on a 32bit microcontroller like the ESP32.
On which microcontroller are you testing?
I am testing using Arduino UNO
do you need it in a buffer (which is later used to be printed) or do you want to get it printed on Serial i first place only?
this post will give you some ideas for both ways:
I am mainly printing it for verification purposes at the moment. I just want some way of seeing if I am correctly doing bitwise operations and things like that. It's for a larger project and I'm struggling with some of the basics. Thanks for linking that post though, I will go check it out
UNO does not know how to print uint64_t
careful as well if you use Arduino's bit manipulation macros as some are tailored for 32 bits max
(see the UL and not ull)
Why not sprintf(msgString, "Incoming message: 0x%.16X",receivedMsg); ?
without the 11 between 16 and X
because that would be for an unsigned integer (in hexadecimal format) and not a unsigned long long
