Printing negative ints, why four bytes
So this code
#include <Arduino.h>
{  Serial.begin(9600);
  int i=1 ;
  int j=-1 ;
  Serial.println(i);
  Serial.println(j);
  Serial.println(i,HEX);
  Serial.println(j,HEX);
Prints this
1
-1
1
FFFFFFFF
Now if the int is 16 bits, should be four hex digits. So why do I get 8 hex digits ?
If I change "i" to some positive number like 512, I get 200 hex.
Because the function Serial.print casts the incoming value to a long, and -1 in long is 0xFFFFFFFF.
yep it is in the Print library code
size_t Print::print(int n, int base)
return print((long) n, base);
you would get the same effect when you used a char j = -1;
